is it true that the hub assemble of an ACURA VIGOR will be a direct bol on to the integra
Old Feb 9, 2002 | 11:24 PM
2kGSboi's Avatar
New User
Default is it true that the hub assemble of an ACURA VIGOR will be a direct bol on to the integra
i was told by a friend that the 5 lug hub assembly from an ACURA VIGOR is a direct bolt on to an integra and has same bolt pattern like type r is that true??? can someone confirm this to me??!?!?!
Old Feb 10, 2002 | 05:51 AM
Cosworth's Avatar
Default Re: is it true that the hub assemble of an ACURA VIGOR will be a direct bol on to the integra (2kGSb
First of all, it doesn't have 5-lugs. It comes with 4x114, just like old Accords. The only difference between the Accord assembly to that of Vigor is a bit larger rotors to stop a much heavier car. Lastly, just as you can't "bolt-on" an Accord hub to a Civic, you can't do it from Vigor either.
btw, it's in the wrong forum.
Old Feb 10, 2002 | 06:09 AM
bus stop's Avatar
I'm not sure about the answer on your question.....however I saw an ITR using Vigor's wheels and no problem....hope this may help.
Old Feb 10, 2002 | 07:52 AM
Cosworth's Avatar
No, unless the ITR you saw was a '96 model w/ 4x114 bolt pattern...
Acura Vigor is re-badged Honda Inspire (in Japan) and they never saw 5-lugs. And, yes, my family owns a Vigor and ours never came with 5-lugs.
Old Feb 10, 2002 | 08:58 AM
d8168055's Avatar
only the new 3.2 TL's (Vigor/Inspire replacement) have the 5-lugs...
2kGSboi
Jan 8, 2007 05:46 AM
paul_type_r
Acura TL, RL & ZDX
Mar 24, 2004 06:48 PM
GSRMatt
Acura TL, RL & ZDX
Jun 16, 2002 03:46 PM
White LX
Oct 25, 2001 11:50 AM
