Hasport A/C mount for D15B7 -> B18C4 swap
Old Jun 9, 2005 | 01:42 AM
ErikV's Avatar
Default Hasport A/C mount for D15B7 -> B18C4 swap
Hello,
I'm going to swap a B18C4 (much like the C1) in my EJ2 Coupe (92-95).
I was told to get another bracket and A/C pump, but I see that Hasport is selling a bracket with which I can retain my current D-series A/C pump.
http://www.hasport.com/Product...1.htm
Has anyone done this and most importantly, what are your experiences with it?
Old Jun 9, 2005 | 06:24 AM
Morhpeous's Avatar
Default Re: Hasport A/C mount for D15B7 -> B18C4 swap (ErikV)
you wouldnt need a new a/c pump just get their bracket and you should be fine.... looks like the stock integra bracket. you may want to call Hasport to make sure they will be the best people to call for this cause it is their product
Old Jun 9, 2005 | 07:27 AM
dwnthehatch's Avatar
Default Re: Hasport A/C mount for D15B7 -> B18C4 swap (Morhpeous)
If you want to go with a cheaper alternative get the dohc vtec del sol (P54) ac bracket or the 97 crv (P7J) bracket. The will cost much less than the hasport mounts and you still yuse your stock ac compressor.
Old Jun 9, 2005 | 07:45 AM
ErikV's Avatar
You are 100% sure I can use my D15B7 A/C pump with the Del Sol A/C bracket?
Old Jun 9, 2005 | 08:20 AM
DutchEG6's Avatar
Default Re: (ErikV)
Yo erik i got a B18 bracket with AC pump for you il take it to Drachten 17th of june
Mentat Ghola
Feb 24, 2009 01:47 PM
Turbo_Mike
Jun 25, 2006 12:19 PM
D16Z6TURBO
Feb 9, 2006 01:48 PM
Nicram
10
Feb 6, 2006 02:46 PM
Soled Out
Jan 5, 2003 09:48 AM
