STUMPED !! Rims question.......
i was wondering if i were to run a 16" rim with a bolt pattern of 5 x 114.3 +40mm will they fit right and everything ?? tire rub or what.. cuz i know how touchy the S is with new rims......??????? also what size tire would u recc if that offset is right for the S2K??? thanks
S2000 comes stock with 16*6.5 fronts with 55mm offsets...... backs are 16*7.5 w/ 65mm offsets..... the higher the offset, the more "inward" the wheel is
So you have to figure out the width difference (half the width diff goes to the inside and half to the outside), then figure out the offset difference. Make sense?
Spoons are - fronts - 16*7 - 45mm (or 35mm) and rears - 16*8 45mm
A 16*7.0 front with a 45mm offset would be 16mm out from stock.... (no rubbing there)
A 16*8 w/ 45mm offset would be 6.5mm (1/2 of the width difference) + 20mm (the offset difference) = 26.5 mm (about an inch) further out than stock wheels.... again, no rubbing there unless you really lower it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RWD_Honder »</TD></TR><TR><TD CLASS="quote">ok once and for all...please someone explain offset to me</TD></TR></TABLE>
spoons are 16*7 w/ 45mm front and 16*8 rears with 45mm offsets.
volk ce28n's & TE37's are about the same width and offsets.
besides that you don't have much choices other than stock or JDM stock.
You can go get some shitty pep boys wheels that will fit, but they probably won't be staggard....and they will be heavy.
yea i see what you are saying..... iam looking for a blk rim with chrome lip... but dont want to spend 3g's alone on rims...... you guys know of anything that matches that criteria for the s2000 ? just shoot some ideas of rims out.. i really like the ssr1 professors i think there called ......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">S2000 comes stock with 16*6.5 fronts with 55mm offsets...... backs are 16*7.5 w/ 65mm offsets..... the higher the offset, the more "inward" the wheel is
A 16*8 w/ 45mm offset would be 6.5mm (1/2 of the width difference) + 20mm (the offset difference) = 26.5 mm (about an inch) further out than stock wheels.... again, no rubbing there unless you really lower it.</TD></TR></TABLE>
This applies to the AP1...not the AP2 (just thought i'd throw that in there).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnosisracing »</TD></TR><TR><TD CLASS="quote">This applies to the AP1...not the AP2 (just thought i'd throw that in there).</TD></TR></TABLE>
Besides the 17's... what is the setup? And what are the stock AP2 offsets & widths?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scot »</TD></TR><TR><TD CLASS="quote">spoons are 16*7 w/ 45mm front and 16*8 rears with 45mm offsets.
The optimal offsets for the CE28 are 17x8.5(F) +50 and 17x9(R)+63.
he asked for 16" sizes........that is why i posted 16" sizes and offsets.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRbroham »</TD></TR><TR><TD CLASS="quote">
The optimal offsets for the CE28 are 17x8.5(F) +50 and 17x9(R)+63. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scot »</TD></TR><TR><TD CLASS="quote">he asked for 16" sizes........that is why i posted 16" sizes and offsets.
Oh ok.
Oh ok.
so as far as 16" rims and your guy's knowledge.... what are my options to go with.. besides the spoons..... ???????????????????????
eh tme rims are nice... but whats available thats Blk with a chrome lip
i have a berlina blk s2k and really like that color combo..... anyone know of any rims out there ????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant »</TD></TR><TR><TD CLASS="quote">what color is the S?</TD></TR></TABLE>
I think he said Berlina.
I posed a similar wheel question to Tom at Gruppe-S and he sold me a set of wheels for my S2K that are 17x7.5 +45 Front, and 17x8.5 +50 Rear. If that helps at all.
*Shortest Answer Possible* Offset: The distance in millimeters from the mounting point of the wheel to the wheel's center line.
Modified by NAallTheWAY at 4:09 PM 6/13/2005
