help with instrument lights....
hey guys.... i have a 00 civic HB Dx and my cluster lights and A/c control lights went out...the cluster still works just no lights...i changed the Instrument lights fuse and when i turn on the lights to see if its working the fuse blows....am i changing the right fuse? if so why does the fuse keep blowing?? TIA
Somewhere in that wiring there is a cut and it is ground itself or touching some other wires. In lamins (sp) terms, your wires are shorting out. Like 13SEC CIV said, check the wires from the fues box to the dimmer switch for any breakage or cuts in the insulation and tape them up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frosty-EG6 »</TD></TR><TR><TD CLASS="quote">Swap out the bulbs.</TD></TR></TABLE>
THe bulbs are fine, its the wiring.
[QUOTE=SOHC4life 96]Like 13SEC CIV said, check the wires from the fues box to the dimmer switch for any breakage or cuts in the insulation and tape them up.
dayum
--you must of saw me at the track this weekend
dayum
i checked the wiring but it goes into that black plastic thing...should i cut it?? or am i not following the right wires...if u guys have pics that would be very helpful.....sorry wiring is not my thing....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocaveli »</TD></TR><TR><TD CLASS="quote">black plastic thing...should i cut it?? ....</TD></TR></TABLE>
if you are talking about the wire loom, yes open it up and check for any open wires
cd5cord_guy
Apr 10, 2009 06:00 PM
19cIvIc94
Jun 3, 2007 05:37 PM
