EK check engine light turn off question
Old Jun 8, 2005 | 03:30 PM
Morhpeous's Avatar
Default EK check engine light turn off question
ok if i were to buy this ek and get it inspected the intake air temp is throwing a code does anyone know which wire turns this light on behind the cluster. so that i can cut it for now so i can get car inspected? ill deal with it later
Old Jun 8, 2005 | 03:31 PM
dizzyek's Avatar
Default Re: EK check engine light turn off question (Morhpeous)
why dont u just take the bulb out
Old Jun 8, 2005 | 03:33 PM
SOHC4life 96's Avatar
The check to make sure the check engine light comes on. I learned that the hard way. I pulled the fuse for the cluster lights in my moms car and it failed smog because her check engine light didn't come on. So......rather than trying to cheat get it fixed. Check to make sure the intake air temp sensor is hooked up or just get it fixed.
Old Jun 8, 2005 | 03:36 PM
Morhpeous's Avatar
Default Re: EK check engine light turn off question (dizzyek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzyek &raquo;</TD></TR><TR><TD CLASS="quote">why dont u just take the bulb out</TD></TR></TABLE>
prob could just do that, is the bulb easy to get to?
Old Jun 8, 2005 | 03:44 PM
Maness's Avatar
Don't they actually just plug into your ECU when they test anyway? Which would tell them there is a code? That's what I thought at least.
Old Jun 8, 2005 | 03:45 PM
Morhpeous's Avatar
Default Re: EK check engine light turn off question (Maness)
i dunno never had a obd-2 car getting inspected in VA
90dteg
Sep 18, 2008 12:54 PM
IP RACING
Dec 26, 2007 09:25 AM
jdm82
Mar 7, 2006 01:08 PM
2.2SICKLUDE
May 5, 2005 06:38 PM
nblock93
Jul 6, 2004 11:52 PM
