2k Si, size of rear hub nut?
Old Jun 8, 2005 | 03:08 PM
yh23's Avatar
Default 2k Si, size of rear hub nut?
im swapping out brakes.
on my 2k Si, what size is the bolt that's holding the hub to the trailing arm??? I'm talking about the big bolt that sits on the back of the hub there, with 4 torx screws around it. Someone listed it as 19mm, but its not.
what size is it?
Old Jun 8, 2005 | 03:44 PM
Archidictus's Avatar
Unceasing Measure
Default Re: 2k Si, size of rear hub nut? (yh23)
Why not measure it with a ruler or tape measure?
Old Jun 8, 2005 | 04:12 PM
mjrage's Avatar
on the back of the trailing arm? If so,Just go and get an axle nut wrench if thats what you are talking about. Just dont forget to buy another one to replace it and then punch it into the axle again.
Old Jun 8, 2005 | 06:23 PM
yh23's Avatar
Default Re: 2k Si, size of rear hub nut? (mjrage)
nevermind, i found the specs....
and no, I could not measure it, don't have a metric ruler on me...
and no, not an axle nut wrench...the axle nut is 32mm.
the nut i was referring to is what connects the hub to the trailing arm. Its **24mm**
pkolaboy
May 19, 2009 10:27 PM
cueto
Apr 20, 2009 08:25 AM
EG6_978
17
Mar 18, 2009 10:16 AM
rollercosta123
Mar 11, 2006 08:52 AM
