Which Motor swap?
Old Jun 8, 2005 | 02:40 PM
DaMmniTz's Avatar
Default Which Motor swap?
The time has come. Single cam has to go. Going with dual cams now. I have a question though. I know it's going to be a b16a with boost later on but I was wondering what crx out there uses what year of the b16a?
Below are the models that i mean. Got it off Honda tech. What would be the simplest most used and easiest to work with?
B16A 88-91 (SiR I)
B16A 92-93 Integra (XSi)
B16A 92-95 (SiR-II)
Thanks.!
Old Jun 8, 2005 | 02:42 PM
Agent STFU's Avatar
Default Re: Which Motor swap? (DaMmniTz)
1st gen B16a would be best, could run it obd0.
With the others, I do believe you have to convert to obd1.
Old Jun 8, 2005 | 02:51 PM
DaMmniTz's Avatar
what model is a first generation b16a ? B16A 88-91 (SiR I)?
I will be buying this from a friend of mines who has a friend that has a wreck yard. How would i tell if it's a 1st generation b16a? Can you tell me where to look at?
Old Jun 8, 2005 | 02:54 PM
Ronin150's Avatar
1. Yes that is the 1st gen.
2. You can look at the injector plugs. If they are black (not sure) then it is obd0. I do know that injector plugs for the obd1 are grey
Old Jun 8, 2005 | 02:56 PM
DaMmniTz's Avatar
alright thanks, that helped alot.
Agent STFU's Avatar
B16A SIR is the first generation B16 that is obd0.
Old Jun 8, 2005 | 03:00 PM
EP3_05's Avatar
Default Re: Which Motor swap? (Ronin150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ronin150 &raquo;</TD></TR><TR><TD CLASS="quote">1. Yes that is the 1st gen.
2. You can look at the injector plugs. If they are black (not sure) then it is obd0. I do know that injector plugs for the obd1 are grey</TD></TR></TABLE>
Injector plugs for OBD0 are a milky color.
DaMmniTz's Avatar
good info
Old Jun 8, 2005 | 04:03 PM
Ronin150's Avatar
Default Re: Which Motor swap? (91civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">
Injector plugs for OBD0 are a milky color. </TD></TR></TABLE>
Didn't remember because I didn't pay attention to the plugs on my old d-series, but I did remember what they looked like for my b.
TrueEm1
18
Jun 26, 2016 04:04 PM
BigPlansNoMoney
Jan 28, 2005 01:11 PM
