DA tranny Help..
sup guys jus got DA couple days ago and i noticed that third grinds so i think i might need i new tranny...i have a 91 RS, wut tranny do u guys recommend? Would a GSR or LS go gud wit it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg »</TD></TR><TR><TD CLASS="quote">Do yourself a favor and check your fluid level first, actually, swap some fresh Honda MTF in and you might be pleasantly surprised at the results. </TD></TR></TABLE>
*edited* I was thinking fluid into clutch not into tranny... lol */edit*
As for a tranny, if the long gears don't bother you or if you drive a lot of highway, look into another LS tranny. If you want faster acceleration look at the gs-r or even b16 tranny. Just remember to choose another cable one otherwise you will need the special mounts that I think Hasport makes for around $350, but I'm not sure. I have a cable b16 on my b20 and it's great
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMbolo »</TD></TR><TR><TD CLASS="quote">as long as its cable it should mount perfect right?...do i need to do anything with the ecu?</TD></TR></TABLE>
and clutch depening on what u replace the tranny with
if its another small spine then no clutch
if its big spine 92+ then new clutch
if you can find a b17a tranny from the 92-93 gs-r. that will be the best... best gear ratios out there. next to ITR
if you wanna rebuild what you have, all you have to do is change out 3rd gear syn.
ghost turtle
14
Apr 30, 2005 10:53 PM
