walbro fuel pump question....
Old Jun 8, 2005 | 11:16 AM
DeKaP's Avatar
Default walbro fuel pump question....
i just got my fuel pump in the mail today for my 88 crx si...but i think they might have shipped me the wrong one but im not sure....maybe you guys could help, this is what it says on it next to the logo
Gss341
08905-3 Made in usa
pat 4500270 5421306
hope they didnt send me the wrong one =/
Old Jun 9, 2005 | 06:42 AM
DeKaP's Avatar
Default Re: walbro fuel pump question.... (DeKaP)
nobody knows?
Old Jun 9, 2005 | 07:19 AM
BlueShadow's Avatar
Sounds like you have the 255lph high pressure pump for 88-91 Civic/CRX's so it looks like the right one. That's the same one I have in my 91 CRX DX. Check out the first link to verify your p/n, and check out the second link if you need some help installing it.
http://www.lightningmotorsport...s.htm
https://honda-tech.com/zerothread?id=1263692
EDIT: the pump adapter kit is what you should be most concerned with. It should have the following parts:
-a wiring haress that plugs into the fuel pump and is spliced into your stock harness
-Walbro fuel pump filter
-small white filter adapter (plugs to bottom of fuel pump, and filter connects to it...just line up the holes on the white adapter to the fuel pump and filter)
-bottom rubber piece (gos on the bottom of the fuel pump)
-two very small washers (couldn't figure out what these were for...so I stuck them on the small pegs to keep the white filter adapter in place)
-two insulated butt connectors
Old Jun 10, 2005 | 07:29 AM
DeKaP's Avatar
Default Re: walbro fuel pump question.... (BlueShadow)
alright i believe i have the right one, just thought they sent me one for a different car
Old Jun 10, 2005 | 07:30 AM
DeKaP's Avatar
they only gave me 1 washer though
Old Jun 10, 2005 | 07:39 AM
BlueShadow's Avatar
Are you sure you didn't overlook the second one in your kit somewhere? you might still be ok, or you could try going to the hardware store and buying one that fits on the white fuel filter adapters pegs.
Old Jun 11, 2005 | 08:10 AM
DeKaP's Avatar
Old Jun 11, 2005 | 09:03 AM
BlueShadow's Avatar
Splock
Jul 30, 2017 08:57 AM
Cute EK
Jan 6, 2006 09:06 PM
marcussmith26
Nov 27, 2005 05:52 PM
JRex89
Mar 16, 2004 02:08 PM
