C/ R question on LSVTEC build up?
Old Jun 8, 2005 | 09:59 AM
123Four's Avatar
Default C/ R question on LSVTEC build up?
Im sure alot of people already ask this question but bare with me.
Im trying to piece together my lsvtec build up.
i want my compression ratio to be around 10.5 - 11.0 only runing 91 octane gas.
what OEM piston should i go with?
as of now im thinkin USDM ITR piston P73. but i heard it might not fit easly on the ls rods?...
are are 99-2000 SI piston part #? is it PR3 or P30?
im going with a 95 b18b bottom with 98 gsr vtec head.
keepin it OBD1... pretty much stock daily driven. hoping to make 175 -180hp.
another question is what the different between CTR piston and P30 piston? when i look a some website they said they sale CTR piston or P30 piston and it kinda confuse me which is which?
alright thats all i hope u guys could help me out. thanks for ur time.
Old Jun 8, 2005 | 10:34 AM
unknown0001's Avatar
Default Re: C/ R question on LSVTEC build up? (123Four)
Check out my post I made a while back
https://honda-tech.com/zerothread?id=1257816
use this site to calculate your compression
http://www.zealautowerks.com/
P73 should work on LS rods.
PR3 are USDM B16A pistons while P30 are the JDM B16A pistons which give off a bit more compression
CTR pistons are much more dome like and give off a higher compression then p30. If you want to be at 10.5-11:1 then I would go with the p30 pistons.
Old Jun 8, 2005 | 11:01 AM
97L-esVeeTeg's Avatar
Default Re: C/ R question on LSVTEC build up? (Mr.RHTuner)
If you want 11:1 comp with a gsr head, go with us itr pistons. pr3's and p30's will set you at about ~11.6-11.9
PCT is the CTR piston, you probably dont wanna use this with 91 oct.
search you should be able to find answers to all of your questions pretty easily
aeros
Feb 13, 2013 10:39 AM
cjmurillo
Dec 25, 2008 08:40 PM
Figgy1682
Aug 1, 2007 09:55 PM
00BlackDc2
Feb 22, 2004 12:13 AM
Rydaddy
Oct 24, 2002 10:34 AM
