y8 Dist Plug question..
Old Jun 8, 2005 | 12:37 AM
s73's Avatar
s73
New User
Default y8 Dist Plug question..
I am swapping out a locked up motor for a friend ( from 2000 y8 to a 2000 y8).
The Dist. plug is different from the two motors, when its should be the same motor! (both 00 y8's)
The wire harness side plug had a 8 pin plug, but on the motor side(dist side) had a 9 pin plug?????
The Dist it self looks the same to me....Any of you guys seen this problem in the past?
please give me some input.
thanks in advance
Old Jun 8, 2005 | 04:21 AM
EE_Chris's Avatar
Default Re: y8 Dist Plug question.. (s73)
Buy a Helms then turn to the ignition section. You'll see that 96-98 Civic's used the 9-pin distributor.
Old Jun 8, 2005 | 12:12 PM
s73's Avatar
s73
New User
Default Re: y8 Dist Plug question.. (EE_Chris)
thanks man, i go take a look
s73
Jul 8, 2005 01:13 PM
hatchback_al
Sep 29, 2004 12:26 AM
Hatebreed215
Jan 17, 2003 08:26 PM
