Deck wont power up, can anyone help?
Old Jun 7, 2005 | 11:39 PM
cam003's Avatar
Default Deck wont power up, can anyone help?
Well i know why the deck wont power up, the ground and + wires got crossed. they were all snipped at the same time and this is what caused the short. my question is can i fix this. i know there is a short some where on the bored i just have to find it, but where do i start? Any help would be great it is an Alpine CDA-D852. A 1.5 DIN it came out of my jeep. any sugestions would be great. thanks to all.
Old Jun 8, 2005 | 11:21 AM
fcm's Avatar
fcm
Old Fart
Default Re: Deck wont power up, can anyone help? (cam003)
Shorting the power and ground, [when being cut at the same time] should not do anything to the HU, it should blow the cars fuse, are you sure that you have power on both the red, [acc. fused in incar fusebox] and the yellow, [constant power, fused in the engine bay fuse box] of the Alpine HU, the oem fuse for constant power, [in engine bay fuse box] is only a 7.5A, your HU may need more power, DO NOT install bigger fuse, instead, run a fused 10ga power wire from batt. to behind the HU and connect the yellow wire from the HU to it. 94
Old Jun 8, 2005 | 07:23 PM
Loccusst's Avatar
Some alpines actually require alot of power, FCM is right, you may actually need to run a power wire to the head unit. Use a DMM and test the head unit to see if it is getting power first. Then check all of the fuses.
Old Jun 8, 2005 | 11:21 PM
cam003's Avatar
Default Re: (Loccusst)
I hooked it directly to a battery on a bech just to test it, i know the deck is the problem i heard it short and saw the deck smoke a little. The car fuses are fine. any other sugestions?
Old Jun 9, 2005 | 05:27 AM
Loccusst's Avatar
If you love the deck send it in for repairs.... otherwise get a new one. If you know what you are doing simply take the deck apart and I am sure you will see a burn spot on the deck board. Then replace that part on the board.
dc2nerz
19
Apr 21, 2012 06:57 PM
JBN241
Audio / Security / Video
Apr 6, 2009 12:27 AM
idumpwitmy12gaugepump
May 22, 2008 07:18 PM
07rebel
12
Jan 27, 2008 04:26 PM
02AccordCoupe
14
Mar 20, 2003 12:32 PM
