for those that have an OEM wing
hey does the high mount brake light work on your cars? mine doesn't. i wanna take it out completely. where can i get the plugs for the holes when i take it out? or can i just leave the plugs/bolts in there?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bk11383 »</TD></TR><TR><TD CLASS="quote">hey does the high mount brake light work on your cars? mine doesn't. i wanna take it out completely. where can i get the plugs for the holes when i take it out? or can i just leave the plugs/bolts in there?</TD></TR></TABLE>
did you plug it in?
did you plug it in?
if you have a 3rd brake light, then you have a plug for it. unplug the wires that run back to the spoiler and plug it into the window brake light. maybe i'll post a pic later, sorry i can't describe it better.....
it's like you have the wires that run to the brake lights, and it's either plugged into the spoiler or the window light. unplug it from one and plug it into the other. it's up under the panel.
The Integra light in the rear window usually comes on with the tail lights in the JDM cars, although there is wiring for a brake light there too.
I've the Integra light and the high level brake light in the wing wired as brake lights, and it doesn't look bad at all IMO...although mine is a G2 and the Integra light is at the top of the rear window. Try it and see
