Question, What is VTECH?!!
can someone please explain to me what exactly vtech is, i tried to find out online and on howstuffworks.com but they dont have it.
what is it, exactly, and how does it work?
i cant understand how an s2000 2.0 liter engine NA puts out 246 hp, vtech must be like a little god or something with wires.
sorry if others asked this question, if theres an article or soemthing i can read, any directions to it would be appreciated. thanks all.
-Andrey
-Andrey
This should be rich, really rich.
What VTEC does is increase the air flow to the engine adding power during a certain RPM range. Do some searching on here and youll find your answer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andreyman »</TD></TR><TR><TD CLASS="quote">can someone please explain to me what exactly vtech is, i tried to find out online and on howstuffworks.com but they dont have it.
-Andrey</TD></TR></TABLE>
i wont be an ******* because this looks like a legitimate question
VTEC. no H.
VTEC stands for Variable Valve Timing and Lift Electronic Control.
here
http://auto.howstuffworks.com/question229.htm
short answer is it increases airflow by changing cam profiles (lift and duration) by using a 3rd rocker arm that gets activated by a locking pin via oil pressure.
VTEC. no H.
here
this should help.. http://www.team-integra.net/se...ID=45
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Senses Fail y0! »</TD></TR><TR><TD CLASS="quote">All the answers to your questions, HERE!!!</TD></TR></TABLE>
Thats not cool.
Thats not cool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andreyman »</TD></TR><TR><TD CLASS="quote">hey everyone thanks for the links that howstuff works article is great plus the links off of it. Thanks to Honda011 too that site is great. Such a simple design and works so well, thats sweet.</TD></TR></TABLE>
Another note: VTEC is not the only - or the first - variable-lift type valve activation system. Ferrari uses a tapered cam lobe system where the actual camshaft moves around in the head for maximum lift and efficiency at any given RPM.
Come on guys. Some of you just don't give people a legitimate chance.
Andrey, here's so good reading material on camshafts:
http://www.tprmag.com/issue/2/2_camshafts.shtml
http://www.elgincams.com/campaper.html
