Installed amp, subs, wiring having problems starting car?
Old Jun 7, 2005 | 07:07 PM
ferby's Avatar
Default Installed amp, subs, wiring having problems starting car?
I just got 2 10" audiobahn subs and a audiobahn amp, hits hard. hehe
Their are times that when I try to start my car it goes click click click then I repeat and same thing then eventually after 30 seconds or so It will start up randomly when I try to start it up again.
What is causing this? I have never expierienced this problem before this auido equipment was installed. My battery plugs are on pretty tight.
all suggestions excepted. thank you
Old Jun 7, 2005 | 07:08 PM
89hbcivicguy's Avatar
Default Re: Installed amp, subs, wiring having problems starting car? (ferby)
sounds like ur alternator is shot
Old Jun 7, 2005 | 07:10 PM
Default Re: Installed amp, subs, wiring having problems starting car? (89hbcivicguy)
take it to a garage and have them do a starter draw test and to see if your alternator is cranking out enough amps.,.......might want to consider a cap too
Old Jun 7, 2005 | 08:10 PM
kcem1's Avatar
how is you amp wired as far as the turn on wire goes if the turn on wire has 12volts all the time that could kill your battery.
Old Jun 7, 2005 | 08:24 PM
lotas's Avatar
Make sure your battery is fine, as thats what is involved in starting the car. The alternator doesn't play a role in starting the car, the battery provides the initial surge.
Don't get a cap unless your alternator is putting out well over enough amps (current) than your amp is drawing, otherwise it will just be another draw on your already struggling alternator and will be pointless.
Old Jun 8, 2005 | 12:48 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferby &raquo;</TD></TR><TR><TD CLASS="quote">I just got 2 10" audiobahn subs and a audiobahn amp, hits hard. hehe
all suggestions excepted. thank you</TD></TR></TABLE>Sounds like the starter solenoid to me, or a poor power connection to the solenoid/starter motor, check the connections at the starter motor, an easy way to check the solenoid is when it just clicks, hold the ign. switch on the start position, and have someone give the solenoid a good solid "tap" or 2, if the motor starts to crank when you do this the problem is down at the starter/solenoid or the wires connected to them, because you can hear the solenoid click, [and I assume the clicking is comming from the solenoid, (mounted to the starter motor) and it's not just the starter relay, (mounted inside the car] I would say that the starter relay and all the wiring to the solenoid are good, I would check the connection to the solenoid of the cable coming from the batt., [the bigger of the 2 wires connected to it] the smaller wire is the trigger for the solenoid that comes from the starter motor relay, [and like I said it sounds like its working] the solenoid does 2 things when triggered, first it "kicks"out a pinion gear on the starter motors shaft to line up with the ring gear on the flywheel, [so it can turn the motor over] second, [and this is where the problem can be] it connects the batt. [bigger of the two wires I asked you to check] to the starter motor itself, if the problem is there, [and intermitant] this will normally show up when you give the solenoid some sharp taps, if tapping the solenoid, [with key in start position] starts the car, then the problem is most likely the solenoid, but can be the connection or the starter motor itself. it is a cheap and easy test to do, and just may be your problem. 94
Old Jun 11, 2005 | 02:56 AM
toomtoomvroom's Avatar
I had the same problem with my accord. I had the starter replaced a few months ago and the problem started. I took it back and they said that the starter was bad so they changed it for free cause it's still under warranty.
Old Jun 11, 2005 | 08:16 AM
GSteg's Avatar
same thing happened to my car. all i heard was click. turns out my battery was dead.
Birdley42008
Audio / Security / Video
Jul 20, 2007 04:07 PM
hopsta
Sep 29, 2004 04:01 PM
hcivic99
Aug 23, 2004 04:44 PM
GroundZer0 336
13
May 23, 2003 06:10 AM
Thrillhouse
Jan 30, 2003 01:47 PM
