ITR rods on a GSR crank ?
Old Feb 9, 2002 | 03:46 PM
TRuST's Avatar
Default ITR rods on a GSR crank ?
What type of rod bearings do I use with ITR rods and a GSR crank ?
Old Feb 9, 2002 | 04:14 PM
Sleeper's Avatar
Default Re: ITR rods on a GSR crank ? (TRuST)
ITR or GSR rod bearings, are one in the same. Unless you are talking about 92-93 GSR crank(81.4mm), then it won't work with R rods, the big end is too narrow.
Old Feb 9, 2002 | 04:56 PM
TRuST's Avatar
Default Re: ITR rods on a GSR crank ? (Sleeper)
Thanks for the info and yeah its for a b18c1.
Old Feb 9, 2002 | 07:08 PM
stick's Avatar
hey warren, i thought u were going for different rods??
Old Feb 9, 2002 | 08:58 PM
sgT's Avatar
sgT
The numbers and letters wont match up on a honda bearing chart.
So you will have to start at a color and measure the clearances until you get it right.
Old Feb 9, 2002 | 09:28 PM
TRuST's Avatar
Default Re: ITR rods on a GSR crank ? (stick)
Stick, I was going to use the probe industries ultra-lite rods, but I'm using JDM ITR pistons and it was recommend to use honda rods with honda pistons.
SGT,
In other words all the tolerances have to measure to find the correct bearings. So, how do I begin finding the correct rods bearing. What size should I start with first ?
[Modified by TRuST, 1:28 AM 2/10/2002]
Old Feb 9, 2002 | 09:48 PM
sgT's Avatar
sgT
If you want to use aftermarket rods with stock pistons, then you have to modify
the pistons to accept retaining clips.
First by getting me the Numbers on the rods and the letters on the crank.
Then I can give you a starting point.
Old Feb 10, 2002 | 07:59 AM
TRuST's Avatar
Default Re: ITR rods on a GSR crank ? (sgT)
No problem, when the rods and the motor are torn down I'll email you.
Thanks help.
[Modified by TRuST, 3:07 PM 2/11/2002]
Old Feb 15, 2002 | 02:05 AM
2fknlo's Avatar
Im doing a similar setup, CTR pistion and ITR rod on GSR Crank, i want to use OEM parts, ITR or GSR Rod bearing,
also should i change the engine bearings to ITR or GSR? Cool thanks guys.
Old Feb 15, 2002 | 07:32 AM
sgT's Avatar
sgT
Default Re: ITR rods on a GSR crank ? (2fknlo)
b18c bearings are the same.
Old Mar 2, 2002 | 07:53 PM
Big Teggie's Avatar
sgT- Should you always replace the bearings, even if you just take the old rods off and put new pistons on, and just put the old rods back on? Also what do bearings usually cost? And one more quick question, do you need to remover the crank to hone the cylinder walls? thanks dude
PACT man
Jan 19, 2009 12:59 PM
wakeboard_dude5
Jul 7, 2006 02:20 PM
xparkesx
18
Mar 8, 2005 09:03 PM
leftySi9900
Jul 12, 2004 07:19 PM
bb6
14
Jun 4, 2003 10:34 AM
