removing lower fork arm nut - need help
Old Jun 7, 2005 | 04:39 PM
dungsta's Avatar
Default removing lower fork arm nut - need help
im trying to add new coilovers to my car and i couldnt get the lower fork arm nut off... its like stuck or something.. i tried using wd-40 but that wasnt much help .. someone please give me a solution to removing this nutt
thanks
Old Jun 7, 2005 | 04:42 PM
mwieczorek43's Avatar
Default Re: removing lower fork arm nut - need help (dungsta)
pneumatic tools own you.
Theres really no solution to this problem. There was like three threads just earlier today about the same thing. Just keep at it, and eventually the bolts will break.
Old Jun 7, 2005 | 04:43 PM
MikeD718's Avatar
You could try heating it with a torch. Post in the suspension forum too and see what they say.
Old Jun 8, 2005 | 02:02 PM
dungsta's Avatar
Default Re: removing lower fork arm nut - need help (MikeD718)
does anyone know where i can rent one of those power tools from? .. i tried using penetrating lubes and it still doenst work.. i need a power gunn..
Old Jun 8, 2005 | 02:41 PM
solareclipseauto's Avatar
try a breaker bar and if that doesnt break the bolt heat it with a torch
Old Jun 8, 2005 | 02:43 PM
SOHC4life 96's Avatar
Default Re: removing lower fork arm nut - need help (solareclipseauto)
Just be sure not to snap the bolt, cause that would suck.
justinwebb
Apr 12, 2009 04:58 PM
dungsta
Suspension & Brakes
Jun 8, 2005 05:06 PM
dungsta
Jun 7, 2005 05:13 PM
4U2NV
Aug 29, 2004 10:11 AM
Magick211
Nov 23, 2001 04:52 AM
