HELP:d16y7 vs. d16y8 oil pans????
Old Jun 7, 2005 | 04:14 PM
vtNaMeSe's Avatar
Default HELP:d16y7 vs. d16y8 oil pans????
are there any differences??? i just cracked my y8 oil pan and i found a y7 one. both are d16's. help anyone???
Old Jun 7, 2005 | 07:46 PM
d16y8EL's Avatar
Default Re: HELP:d16y7 vs. d16y8 oil pans???? (vtNaMeSe)
IT'll work no prob.
Old Jun 7, 2005 | 07:53 PM
Redline96LX's Avatar
* B A N N E D *
they are not IDENTICAL. Yes it will work. Only functionality difference is the oil pan drain plug bolt. The y7's is torqued to 33lb-ft and the y8's one is torqued to 29lb-ft. The y7 takes a slighly "wider" (not necessarily thicker) oil pan gasket. Information verified via my Helm's manual.
Old Jun 7, 2005 | 09:09 PM
fishnfst's Avatar
I'm currently using a y8 pan on my y7-t and it works fine......
Old Jun 8, 2005 | 03:13 AM
vtNaMeSe's Avatar
Default Re: (fishnfst)
thanks for the helps guys.....i guess im gonna get that oil pan then. should i use the y7 gasket or use the y8?
kaychi
Jan 27, 2009 06:34 PM
r1ch1e
Mar 28, 2006 10:45 AM
willyboyK20
Oct 22, 2002 08:22 AM
