b series bellhousing pattern
i could really use some help on something
i recently got ahold of an s2000 transmission and was curious if the b series bolt pattern was the same.
i check my accord pattern and its slightly differnt and the accord flywheel is too large but i know the b series stuff looks similar and the flywheel is smaller the easiest way for you to check for me would be to measure the top bell bolt spacing on the s2000 i think it was 5.25 inch but not sure
also any bellhousing pics or rear of the engine pics would help
thanks
thanks
yes im going rwd drive with this the bellhousing is smaller than a reguler f or h series bellhousing can you measure the distance between the center of the top two bell bolts for me
charosenz
Transmission & Drivetrain
Dec 18, 2016 06:16 PM
TravisCadello
Feb 3, 2010 11:44 AM
elektronsi
Apr 18, 2008 03:18 PM
