Problems removing head
alright i'm parting out my crx, and i'm having touble removing the head from the block. i've disconnected everything ive needed to from the head. Meaning the head is completly bare and not a single hose or anything is attach to it. cam gears, camshafts. manifold, head studs, vtec selenoid all off. I tried lifting it off with with my hands but wont budge. what am i forgetting?
ok i just wanted to also add that its dohc not sohc if that helps me any. Also there is a female bolt pattern on the drivers side of the head that i havent touched, could that be it? hope everyone knows what im trying io describe.
Tap on it with a rubber mallet
It shouldn't take much to break it loose... check over it again and make sure there aren't any more bolts or brackets holding it on there.
There is nothing actually holding the head to the block besides the head bolts themselves. Provided they are all removed, the head should come off. You could try bolting one of the manifolds on with a few bolts for some leverage so that you can rock the head loose. By the way, what kind of motor is it. B-series DOHC motors have multi-layer steel head gaskets. And these types of gaskets don't tend to adhere the head to the block.
RSSEXtype-sizzle
Aug 12, 2012 09:46 PM
packman5280
Apr 10, 2008 06:15 AM
89dxhunchback
Jan 13, 2005 01:53 PM
