HELP!!!!!! PLEASE!!! REMOVING OIL PAN......IM STUCK...........
Old Jun 7, 2005 | 12:47 PM
Hatch It's Avatar
Got it.
Modified by Hatch It at 11:31 PM 7/6/2005
Old Jun 7, 2005 | 12:50 PM
Luserkid's Avatar
Default Re: HELP!!!!!! PLEASE!!! REMOVING OIL PAN......IM STUCK........... (Hatch It)
You have to take off the flywheel cover and it will reveal the 2 nuts that you have to take off.
Flywheel cover is held on by 2 14mm bolts, unless if your like me and its only 1. Anyway take those off and the flywheel cover should slide right down.
Old Jun 7, 2005 | 12:53 PM
mike1114's Avatar
SEARCH is your friend.
You must remove the flywheel cover (Plate your referring to)
Once you remove it you can get to those last two bolts.
Once those bolts are removed, hit the pan with your palm or a rubber mallet and it will come right off.
If motor is GSR you need to remove engine stiffeners also to get flywheel cover off.
Old Jun 7, 2005 | 12:54 PM
EJ1 wilcox's Avatar
Default Re: HELP!!!!!! PLEASE!!! REMOVING OIL PAN......IM STUCK........... (mike1114)
Yeah, just remove anything that gets in the way.... including the tranny braces if you have them.
Old Jun 7, 2005 | 02:08 PM
BoostedCivic85's Avatar
Default Re: HELP!!!!!! PLEASE!!! REMOVING OIL PAN......IM STUCK........... (EJ1 wilcox)
Sup, you have to take off the tranny brace, not sure about the flywheel cover, I don't think so but I can be wrong. Good luck.
RACEPAK
18
Jul 11, 2005 06:21 PM
stripes777
Oct 11, 2004 01:28 PM
lildrgn2.0
Jun 22, 2004 06:56 AM
90crxsib16
Jun 3, 2004 04:52 PM
