HELP with rewiring SI harness into DX driverside harness(san diego)
i need help with a rewiring. I did a swap for my crx. I installed a 91 SI motor into a DX shell. I have the Si ecu, Si harness, and motor, but the Si harness doesn't plug into the DX harness that is located on the drivers side(the one that goes under the dash and to the lights). I need help to wire the Si harness to that DX harness. If anyone can help me that will be great. If someone is located in san diego, and can do it for me, give me a price. I was told that its easy if u know what ur doing. thanks
If you're doing a DX to Si swap, your only option is to modify the DX harness to work with the Si Engine, You do not use the Si harness for anything but the plugs. See Rywire.com - we specialize in this. The conversion is $160, you send us the DX and Si engine harnesses UNCUT
(unscrew and unbolt the ground points, if you cut them off it's going to cost ya)
You're welcome to call the phone # on Rywire.com, you'll get me.
itztrixxx
Oct 26, 2006 07:25 AM
