ls cams
Old Jun 7, 2005 | 11:32 AM
hondatuner20's Avatar
Default ls cams
how much hp would my 92 ls get from some mild crower cams? also i already have i/h/e. im asking because idont want to buy them if they are not worth it.
Old Jun 7, 2005 | 12:14 PM
bottlefed13's Avatar
Default Re: ls cams (hondatuner20)
if you plan on doing cams, you might as well do the whole valve train. if you don't you might have valve float. just my .02
Old Jun 7, 2005 | 01:03 PM
Ronin150's Avatar
Default Re: ls cams (bottlefed13)
What is valve float?
Old Jun 7, 2005 | 01:16 PM
Default Re: ls cams (Ronin150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ronin150 &raquo;</TD></TR><TR><TD CLASS="quote">What is valve float?</TD></TR></TABLE>
it's when the lobes on your aftermarket cams push your stock valves and springs down too far. the bottom of you valves then hit the top of your pistons. your stock valve springs are not meant to hold the push down force of aftermarket cams.
Old Jun 7, 2005 | 01:24 PM
Ronin150's Avatar
OK, never heard that term before. I was thinking it was the other way around where they would be stuck open.
Learn something new everyday, and knowing is half the battle.
Old Jun 7, 2005 | 01:52 PM
hp numbers any one??
Home Wrecker
Aug 18, 2006 05:50 AM
redlseg
Jun 27, 2005 06:53 AM
mugenracer
Mar 13, 2005 09:29 PM
dc5r2002
Jun 16, 2004 03:41 AM
