is it safe to run .25 over in 12.5.1cp ls block
Old Jun 7, 2005 | 11:32 AM
hybridpatient95's Avatar
Default is it safe to run .25 over in 12.5.1cp ls block
yea im wondering if its safe to run a 82mm bore over the stock 81 mm in the ls block with 12.5.1 cp in a ls vtec.. that will probably only see about 8500 with a full block girdle.. thanks alot!
Modified by frankenfiend 04 at 3:32 PM 6/14/2005
Old Jun 7, 2005 | 12:52 PM
cmon guys!
Old Jun 7, 2005 | 03:26 PM
Rocket's Avatar
Default Re: (frankenfiend 04)
CP has 0.50mm over.
Good bore and hone ranges from $125 to 175.
Proper honing requires overstroking it and if your guy is not used to honda's it's hard to avoid some taper.
Old Jun 14, 2005 | 11:32 AM
bump!! 82 mm safe on a 12.5cp ls vtec?
Old Jun 14, 2005 | 11:41 AM
Phatch99's Avatar
82mm is max on ls block you should be fine with good tuning.
Old Jun 14, 2005 | 11:46 AM
thanks alot man! i thought it was gonna be safe.. so no more than 82.. other than that sleeve it... umm how much are 84 mm sleeves anyone know?
Old Jun 14, 2005 | 12:17 PM
Phatch99's Avatar
sleeves i think are around $500 - $600 and installation depending on where u go should be around $700 - $900.... correct me if i'm wrong guys....
DIFFUT'S INC.
Apr 6, 2010 01:20 PM
trbcivic
Dec 9, 2003 11:22 AM
wm5holla
Apr 6, 2003 11:25 AM
eg6sir-s
Mar 22, 2002 08:44 PM
