ZC TRANNY OIL SEAL INFO!!!!!!
Old Feb 9, 2002 | 02:02 PM
Xstatic's Avatar
Default ZC TRANNY OIL SEAL INFO!!!!!!
I finnally found the info on the oil seals for the zc tranny !!!!!
AXLE SEAL'S:
Because the JDM L3 "ZC" tranny was paired with a 1.6l DOHC powerplant, it was designed to use the larger "Integra sized" inner CV joints with the 40mm splined shafts. The bore in the transmission casings is the same as the USDM L3 transmissions, so the outside diameter of the seals is the same. However, because of the larger caliber splined axle shafts, you will need the larger inner diameter seals.
Here are the part numbers for the seals. Your local Honda dealer can order them.
AXLE SEAL PART NUMBERS:
Left==91205-PL3-B01
Right=91205-PC9-711
julio_bOostamante
Nov 21, 2006 02:07 PM
jeffruby
Sep 22, 2006 10:54 PM
EG8R
Aug 3, 2006 07:09 PM
Xstatic
Feb 9, 2002 02:03 PM
