84mm bore on an lsvtec
would it be safe to bore out my motor to 84mm on stock sleeves for a semi daily driver. this is wut my block has:
ls block
acl bearings
block guard
main girlde kit
itr oil pump
arp rod bolts
arp head bolts
balanced crank shaft
p30 pistons
stock b16 head
chipped p28 ecu
ls block
acl bearings
block guard
main girlde kit
itr oil pump
arp rod bolts
arp head bolts
p30 pistons
stock b16 head
chipped p28 ecu
You got alot to learn kid, you cant bore an ls to 84 mm on the stock sleves, nor can you run a p30 piston in an 84 mm bore. Send you block to bensons, golden eagle, or rs machines and have them sleve and bore your block set aside a grand for that. Now your gonna need after market pistons, cp, arias, import builders sd's, set aside 450-550. Aftermarket rods, eagle, crower ect 300-600. New bearings ect.
