What year shocks will fit my '93 Teg?
Old Jun 7, 2005 | 08:11 AM
The Flying Dutchmen's Avatar
Default What year shocks will fit my '93 Teg?
Hey all,
I got a '93 Integra GS and my driverside front spring broke a little while ago. It's been scapin the shock not to mention probably hell on it. I am lookin to get a replacement part and was just wondering the range of years for shocks that will fit. Also will shocks from any other Honda/Acura product work??
Thanks!!
Old Jun 7, 2005 | 10:50 AM
kyle92integ's Avatar
90-93 tegs rs/ls/gs and im not positive but i think 88-91 civic shocks will fit too witha little if any modifications but dont go for number two unless someone confirms it
Old Jun 7, 2005 | 11:36 AM
purplegsr's Avatar
Default Re: (kyle92integ)
88-91 Civic shocks will bolt up fine, but they are shorter than the DA shocks, so if you are only replacing one side, you won't want to do it. You can also use the front shocks from a 94-01 Integra or 92-00 Civic as long as you use the front drop forks from those cars. The rear shocks can be switched to 94-01 Integra or 92-95 Civic with no additional parts, bolts right up. The height will be slightly different, so I would not just change one side, if you are going to switch to a different car's shocks, you should do all 4 at the same time.
Old Jun 7, 2005 | 06:55 PM
wow, thanks alot man. just replacing one so i'll look for a 90-93 teg but appreciate all the info
Old Jun 19, 2005 | 12:38 AM
vt3cvix3n's Avatar
Default Re: (The Flying Dutchmen)
hrrmmm...
would EF front shocks bolt up fine to DC's? i heard they give more travel?
Ep1dem1c
Suspension & Brakes
Feb 28, 2008 11:45 AM
chromedome
Mar 25, 2002 06:59 PM
