need a little DA help.... :(
ok... here i am again.. posting bout my POS DA... just a quick questions 4 ya guys...
here is a quick scenario of what happened.. my car was fine last week... i parked it on friday morn... left for the weekend, got back sun aft and guess what... she wont start.... thing is that she turns over just fine but wont catch... another weird thing bout his is that the exhaust kinda starts to kick in when you feather the gas.. but she still wont start. i towed her to the shop and they are taking 4 ever to even look at her... im thinking its maybe the timing belt, r fuel filter/pump.. ne other suggestions??
why would you think its the timing belt? if it is, your motor is completely fucked already... check for spark, then fuel, then do a compression test.. if ya got all three, she should fire up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoUTX98GSR »</TD></TR><TR><TD CLASS="quote">why would you think its the timing belt? if it is, your motor is completely fucked already... check for spark, then fuel, then do a compression test.. if ya got all three, she should fire up.</TD></TR></TABLE>
some mechanic said it might be that.... well my guy got it running... he said that it was smoking like a bitch for a mn.. but it seems ok... he also said sumthing bout oil and gas in the cylinders.. not sure exactly what he was talking about since his cell was cuttin in and out.. all i know is its running.. for now... but it cost me $90 to NOT find out the problem....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meotch »</TD></TR><TR><TD CLASS="quote">check the cel dude.. it is your key to many mysteries</TD></TR></TABLE>
This dudeETTE checked that.. its fine.... thanks tho
lol sorry!!
check the distributor and wires, you might have a bad wire or something causing it to crap out... im not really sure why it would be doing that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoUTX98GSR »</TD></TR><TR><TD CLASS="quote">if theres oil in the cylinders then your rings could be bad.. that means your motor needs a rebuild.</TD></TR></TABLE>
well i guess there WAS oil in the cylinders... i replaced my gasket bout a 2months ago and that stopped the leak... but just sopped up the oil in there yesterday....hopefully it will be ok...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rah Rah »</TD></TR><TR><TD CLASS="quote">Could also be bad valve stem seals. Cheaper than a ring job
cud have been.. but i chnged them when i changed the gasket.... so they sould be fine now....
</TD></TR></TABLE>cud have been.. but i chnged them when i changed the gasket.... so they sould be fine now....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mattb16teg »</TD></TR><TR><TD CLASS="quote">had a problem similiar to that, it checked out that it was the dizzy.</TD></TR></TABLE>
yea... sad thing is that i have gone through 2 dizzys in the last 6months.... grrrrr
so it better not be that AGAIN...
id say change the wires see how it is my car wouldnt start and then it kick over and then die. turned out to be ******* wires. also check ur main relay see if u switch it with a different one(if u can get ur hand on one) if that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceHungLO »</TD></TR><TR><TD CLASS="quote">id say change the wires see how it is my car wouldnt start and then it kick over and then die. turned out to be ******* wires. also check ur main relay see if u switch it with a different one(if u can get ur hand on one) if that helps.
btw too bad u dont live this way cause if u were and hot id just fix ur car for a small fee
just put new aftermarket wires on her... i also thought that was the problem.... i think i will check the relay switch.. lots of guys are tellin me to take a peek at that....
and thanks for saying im not hot!!!!
hahaha.. im just kiddin... it doesn't bother me if ya dont think i am...
</TD></TR></TABLE>just put new aftermarket wires on her... i also thought that was the problem.... i think i will check the relay switch.. lots of guys are tellin me to take a peek at that....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SiKDA8 »</TD></TR><TR><TD CLASS="quote">
hahaha.. im just kiddin... it doesn't bother me if ya dont think i am... </TD></TR></TABLE>
u havent shown me a pic for my jaw to drop yet
hahaha.. im just kiddin... it doesn't bother me if ya dont think i am... </TD></TR></TABLE>u havent shown me a pic for my jaw to drop yet
well i didnt check it this weekend.. but it has been running fine that last few days *thanks God*
since i no longer have a guy to help w me w it.. can someone tell me how to check it??
