Will a JDM fender fit on a USDM CRX?
Old Jun 7, 2005 | 07:50 AM
GearDownCRX's Avatar
Default Will a JDM fender fit on a USDM CRX?
I have a 1988 Crx Si & I'm planing to put JDM fenders on my car but I don't know if they would fit. I see no problems with the fitment except at where the coner light fits I don't know if JDM coner lights differ form USDM coner lights. Because if the JDM coners wrap around longer than the USDM lights then I will have to get different head lights with inturns that I'll need a different front end for the head lights. So if any has any insight on this problem it would help me out alot.
Old Jun 7, 2005 | 08:18 AM
Del Sol SiR's Avatar
Default Re: Will a JDM fender fit on a USDM CRX? (GearDownCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GearDownCRX &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1988 Crx Si & I'm planing to put JDM fenders on my car but I don't know if they would fit. I see no problems with the fitment except at where the coner light fits I don't know if JDM coner lights differ form USDM coner lights. Because if the JDM coners wrap around longer than the USDM lights then I will have to get different head lights with inturns that I'll need a different front end for the head lights. So if any has any insight on this problem it would help me out alot. </TD></TR></TABLE>
yes the fenders will fit only difference is that it has side markers
Old Jun 7, 2005 | 08:23 AM
EFRue57's Avatar
Default Re: Will a JDM fender fit on a USDM CRX? (DELSOLEMITE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DELSOLEMITE &raquo;</TD></TR><TR><TD CLASS="quote">
yes the fenders will fit only difference is that it has side markers</TD></TR></TABLE>
This is only partially correct. If you get ef8 fenders, they will not fit. Those are the fenders that come with the jdm front end with the wrap around bumper lights. If you get the ef6 or ef7 front fenders, they will fit. That is from a ZC front end.
Old Jun 7, 2005 | 08:35 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: Will a JDM fender fit on a USDM CRX? (EFRue57)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFRue57 &raquo;</TD></TR><TR><TD CLASS="quote">
This is only partially correct. If you get ef8 fenders, they will not fit. Those are the fenders that come with the jdm front end with the wrap around bumper lights. If you get the ef6 or ef7 front fenders, they will fit. That is from a ZC front end.</TD></TR></TABLE>
Not true. The fenders fit the same on all usdm, zc and sir models. I have done a number of them. Even the little clips for the side markers from 88-89 models can be switched from 90-91 models.
Old Jun 7, 2005 | 08:38 AM
Default Re: Will a JDM fender fit on a USDM CRX? (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">
Not true. The fenders fit the same on all usdm, zc and sir models. I have done a number of them. Even the little clips for the side markers from 88-89 models can be switched from 90-91 models.</TD></TR></TABLE>
that what I was thinking, I have both ef8 n' ef7 fenders in the garage and its just the clip you change for the 88-89 & 90-91 corner lamps
Old Jun 7, 2005 | 01:13 PM
ukdm crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFRue57 &raquo;</TD></TR><TR><TD CLASS="quote">This is only partially correct. If you get ef8 fenders, they will not fit. Those are the fenders that come with the jdm front end with the wrap around bumper lights. If you get the ef6 or ef7 front fenders, they will fit. That is from a ZC front end.</TD></TR></TABLE> No the only way jdm fenders wont work on a usdm crx is if it's a 88-89 fender on a 90-91 casue then you gotta also swap corner lights, or vis versa. or change the clips like others said.
Old Jun 7, 2005 | 05:05 PM
SETI20's Avatar
no no no.....
CRX-CRX will fit. No matter where it came from, or what year it's from. Only difference is the trimming and maybe a plastic corner clip. And ofcourse sidemarkers.
CIVIC/CIVIC same deal.
CRX-CIVIC will not fit. EF/ED/EE whatever. Just keep that in mind, and don't let anyone confuse you.
Old Jun 7, 2005 | 05:34 PM
kid-crx's Avatar
Default Re: (SETI20)
http://hmotorsonline.com/shop/...40001
http://hmotorsonline.com/shop/...40002
will either of these front end conversions (not sure what the difference is between the ef8 and ef9) fit on my usdm 88 crx si and how easy of an install will it be
also i have a carbon fiber hood that i dont want to get rid of...it says that it comes with a new hood does that mean that i have to use that one of will my cf still fit?
TIA
Old Jun 7, 2005 | 05:37 PM
kid-honda's Avatar
Default Re: (supportRhondas)
If you have a CRX you want the ef8
EF8=CRX
EF9=Civic hatch
And yes all 88-91 fenders are the same as long as they are crx fenders and as said the only differences and mouldings, corner clips and sidemarkers.
And no your hood WILL NOT fit.
Old Jun 7, 2005 | 06:02 PM
SETI20's Avatar
What's the use of a front conversion if you're keeping your old parts...??
Old Jun 7, 2005 | 06:37 PM
M-doc yo!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supportRhondas &raquo;</TD></TR><TR><TD CLASS="quote">http://hmotorsonline.com/shop/...40001
TIA</TD></TR></TABLE>
either one will fit. It's just that the EF8/CRX one will look more proper on a crx.
Yeah the EF9 will fit, I put one on my CRX. Fenders bolt right up too.
Old Jun 7, 2005 | 06:39 PM
kid-crx's Avatar
alright so ef8 is what i need thanks guys
Old Jun 7, 2005 | 09:22 PM
ukdm crx's Avatar
Default Re: (kid-crx)
Why replace your fenders if you dont need to? Just buy the sidemarks and cut your own holes and save some money.
Old Jun 8, 2005 | 03:10 PM
kid-crx's Avatar
Default Re: (ukdm crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">What's the use of a front conversion if you're keeping your old parts...??</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ukdm crx &raquo;</TD></TR><TR><TD CLASS="quote">Why replace your fenders if you dont need to? Just buy the sidemarks and cut your own holes and save some money.</TD></TR></TABLE>
first of all i was asking about my hood cause its a $400 carbon fiber hood and i would kind of like to use it still
and my fenders are rusted and definatly not repairable
Old Jun 8, 2005 | 05:01 PM
ukdm crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-crx &raquo;</TD></TR><TR><TD CLASS="quote">
and my fenders are rusted and definatly not repairable </TD></TR></TABLE> Ok I see well since the fenders are the same except for the holes for sidemarkers don't get suckered into buying a grip for some JDM fenders when usdm ones work fine.
Old Jun 8, 2005 | 05:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ukdm crx &raquo;</TD></TR><TR><TD CLASS="quote"> Ok I see well since the fenders are the same except for the holes for sidemarkers don't get suckered into buying a grip for some JDM fenders when usdm ones work fine.</TD></TR></TABLE>
lol randy you're replying to someone who jacked GearDownCRX 's post...
Old Jun 8, 2005 | 05:20 PM
kid-crx's Avatar
Default Re: (DELSOLEMITE)
lol randy you're replying to someone who jacked GearDownCRX 's post...</TD></TR></TABLE>
urkcrx
Oct 8, 2007 03:57 PM
k20EP3
Nov 12, 2006 09:15 PM
CWBETB
Feb 4, 2006 07:40 PM
waysian asian
May 17, 2005 10:57 PM
Kool Blue Lude
Nov 14, 2003 02:36 PM
