ef axle question for swap,searched but cant find answer i need
Old Jun 7, 2005 | 05:07 AM
b16std's Avatar
Default ef axle question for swap,searched but cant find answer i need
i am going to be doing a 98+itr swap in my 89 civic std...already has a b6a2 in it ran obd1 using 99-00 si axles with 90-91 outter joints..but the cv joints click..is there a setup i can use without putting to together? would i have to change axles seals etc?
Old Jun 7, 2005 | 06:30 AM
b16std's Avatar
Default Re: ef axle question for swap,searched but cant find answer i need (b16std)
bump
Old Jun 7, 2005 | 12:34 PM
b16std's Avatar
ttt
Old Jun 7, 2005 | 06:39 PM
b16std's Avatar
bump again, no one knows?
Old Jun 7, 2005 | 06:43 PM
EP3_05's Avatar
You can use pretty much any b series axles as long as the axles and intermediate shaft are from the same car. I have been using 90-93 integra axles and matching intermediate shaft.
Old Jun 8, 2005 | 05:06 AM
b16std's Avatar
Default Re: ef axle question for swap,searched but cant find answer i need (91civic)
so if i am using a 98+ itr motor/trans with that intermidaite shaft that i can use those axles? i heard something about if used 90-93 teg shaft/axles i would have to change the tran seal?
Old Jun 8, 2005 | 11:26 AM
b16std's Avatar
bump
Old Jun 8, 2005 | 06:43 PM
b16std's Avatar
ummm ok guess i give up
Old Jun 9, 2005 | 07:19 PM
chadmasterc's Avatar
bump cause i would like to know too. IM looking to swap in an itr engine/tranny and wondering if i should use ITR axles? Im running 90-93 integra axles right now with my b16, but i figure itr axles would be stronger.
Old Jun 9, 2005 | 07:27 PM
mr. carpenter's Avatar
Originally Posted by b16std
bump
i can't help but that's very creative
Old Jun 9, 2005 | 07:48 PM
1badcrx's Avatar
i had ls axles on my b18 crx, worked fine. you can go to autozone and pretty much get free axles every time you break one, as long as you return the broken ones.
Old Jun 9, 2005 | 08:02 PM
Default Re: ef axle question for swap,searched but cant find answer i need (1badcrx)
Well it is pretty much known by everyone that 90-93 axles are the ones to use for b-series cable tranny's in the ef chassis.
The real question is what axles do you run when using a b-series hydro tranny in the ef chassis? It would be great to hear from someone who has actually done this.
and yes ive tried searching.
Old Jun 9, 2005 | 08:31 PM
91sihatch's Avatar
Default Re: ef axle question for swap,searched but cant find answer i need (chadmasterc)
B-serie trannies are all the same size are they not. Just one is cable controlled and the other is hydro. Therefore you should just be able to bolt the ITR engine/tranny right in with 90-93 integra axles.
Old Jun 11, 2005 | 06:49 AM
b16std's Avatar
Default Re: ef axle question for swap,searched but cant find answer i need (91sihatch)
but would i have to change the axles seals so i dont leak all over? just what i heard but not 100% sure..if so i will go order em up..swaps on it way in just got to figure the axles probs 1rst ..and also what ecu should i run chipped p28? if so what program?
Old Jun 11, 2005 | 09:49 AM
JapJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">You can use pretty much any b series axles as long as the axles and intermediate shaft are from the same car. I have been using 90-93 integra axles and matching intermediate shaft.</TD></TR></TABLE>
What he said.
Old Jun 11, 2005 | 10:20 AM
99teggsr's Avatar
Default Re: ef axle question for swap,searched but cant find answer i need (JapJunkie)
raxles.com , anything else you have to remove dust seals and stuff.
Old Jun 11, 2005 | 02:15 PM
b16std's Avatar
Default Re: ef axle question for swap,searched but cant find answer i need (99teggsr)
yeah the dust seals are removed already with the setup i got now
Old Jun 14, 2005 | 07:15 AM
b16std's Avatar
bump
jdmallmotorhatch
Oct 28, 2008 09:57 AM
bipedbear
Apr 4, 2006 12:33 PM
88 rex
Jul 29, 2005 07:49 PM
oneslodx
May 26, 2004 11:57 PM
scratchy
Apr 10, 2004 01:46 PM
