need help: problem with alternator.
Check all ground straps on engine(tranny,head and engine wiring harness ground on the thermosat housing)
Check main power lead off of the battery to the Alt(white wire secured with 10mm nut) could be loose or in my buddys case at expo 5 broken off
Check and see if Alt. is charging
Just my 2 cents, good luck
jsoccer
Aug 18, 2010 01:18 PM
crxhf19
Dec 13, 2006 09:46 AM
