obd0 timing belt cover questions
i got an obd0 jdm b16 swap and i need the lower and upper timing belt cover what b series motor can i get the cover from i was told that0bd0 jdm b16 swap is the same as a del sol do i have to use that one or are all b series timing belt cover the same and where can i get this cover from
No, not any b series cover set will work. Get a set for a 99 Civic Si b 16. I had to do this too.
http://www.hondaautomotiveparts.com/
