Welding thin .035 aluminum tubing to intake manifold flange???
Old Jun 6, 2005 | 07:42 PM
Justin Olson's Avatar
Default Welding thin .035 aluminum tubing to intake manifold flange???
How hard would it be to weld these really thin velocity stacks to my intake manifold flange??? Is it doable? They are aluminum with .035" wall thickness. I'm welding it to a cast factory flange.
These stacks are inexpensive and have a nice taper like the full-race units.
Thanks for the help.
Justin
Old Jun 6, 2005 | 08:32 PM
tony1's Avatar
Default Re: Welding thin .035 aluminum tubing to intake manifold flange??? (Justin Olson)
It's not hard at all, you just need an experienced welder. If you don't think you can do it, you probably can't. Find a good fabricator in your area and he should be able to do it, no problem.
Old Jun 6, 2005 | 08:44 PM
Default Re: Welding thin .035 aluminum tubing to intake manifold flange??? (tony1)
Thanks buddy. Your always there when I need ya
Btw, these stacks are from here:
http://www.tperformance.com/st...tacks/
Once you cut the part that is supposed to be inserted in the carbs, the ID is ~44.5mm.
They have a nice taper like the full-race stacks but just $20 a piece
Old Jun 7, 2005 | 01:03 PM
boostedfe3's Avatar
those stacks look good for the money. what size are the ones you bought? I am looking to add these to my sheet metal intake manifold.
Old Jun 7, 2005 | 03:43 PM
Default Re: Welding thin .035 aluminum tubing to intake manifold flange??? (boostedfe3)
I bought the 5" 48mm IDF ones. Once I cut off the beaded groove at the bottom they are 4.5" tall and have a ID of ~44.5mm.
Regards,
Justin
Old Jun 7, 2005 | 03:46 PM
Old Jun 7, 2005 | 07:17 PM
KFMRC's Avatar
Hate to be negative but I think you are going to have allot of problems with cracking due to the very thin wall thickness most sheetmetal intakes are 3 to 4 times as thick good idea but they are to thin and there is to much vibration at work besides the wieght of the plenum and throttle body
bob kasper
kasper fabrication & machine
kfm race cars & components
609-851-2810
Old Jun 7, 2005 | 07:18 PM
azfab1031's Avatar
as somone else said welding those should be no problem. The only thing that is that sometimes welding to casted aluminum is a bitch it just depends on the casting quality. Either way it should be doable.
Old Jun 7, 2005 | 08:54 PM
Default Re: (azfab1031)
I'm taking into account the thin runners and adding aluminum braces to attach the plenum to the flange.
Justin
Old Jun 8, 2005 | 12:42 AM
project dc2's Avatar
Default Re: (Justin Olson)
whoa where did you get the alum tubing in the D shape ? magnum intakes or somethign ?
Old Jun 8, 2005 | 03:08 PM
Default Re: (project dc2)
Plenum- Ross machine racing
http://cgi.ebay.com/ebaymotors...=WDVW
Old Jun 8, 2005 | 06:38 PM
hulkhb's Avatar
nice mock up man, keep us posted on the project.
Old Jun 9, 2005 | 03:25 AM
RMRf23's Avatar
looks hot justin
it's cool seeing the material you market out there being used... keep us, especially me on how it turns out for you
Old Jun 10, 2005 | 08:33 AM
tuanhoprosk8's Avatar
Default Re: (RMRf23)
thats crazy... i just got a tig welder so i think im going to start projects like this!!
good job man
Old Jun 13, 2005 | 02:59 AM
drunknbass's Avatar
wouldnt you need to heat the stacks and flange up to weld that. and by the time you did that wouldnt the heat warp those stacks since they are so thin?
jmeyer99
Jun 29, 2012 10:24 AM
TXcivic96
Welding / Fabrication
10
Jul 7, 2009 09:38 AM
integrawow
Jun 26, 2007 05:05 PM
Johnny O A20 KIller
Apr 16, 2006 02:57 AM
