FS: GC coilovers, RC throttle body, GSR engine harness/ ECU / distributor
Old Jun 6, 2005 | 07:18 PM
LeftCorner's Avatar
Default FS: GC coilovers, RC throttle body, GSR engine harness/ ECU / distributor
Set of Ground Control coilovers for 90-93 Integra with adapters for use w/ Koni Yellow's. Used them for about a year and a half. Spring rates are 300F/280R. $230 shipped
RC Engineering 62mm throttle body. This is a stock TB bored to ITR specs. Comes complete. $130 shipped
'96 GSR engine wiring harness. Only the harness for the engine compartment, complete and uncut. $100 shipped
'96 GSR ECU. $75 shipped
'96 GSR distributor, complete minus the coil. $125 shipped
lefcorner@aol.com
Old Jun 6, 2005 | 08:04 PM
pissedoffsol's Avatar
25 Year Member
Default Re: FS: GC coilovers, RC throttle body, GSR engine harness/ ECU / distributor (LeftCorner)
pics of the throttle body? does it come with all the sensors and the spring/throttle return
Old Jun 7, 2005 | 07:38 PM
LeftCorner's Avatar
Default Re: FS: GC coilovers, RC throttle body, GSR engine harness/ ECU / distributor (pissedoffsol)
Here's a pic of the TB, comes complete.
Link in case pic doesn't show.
Old Jun 8, 2005 | 07:14 AM
25 Year Member
cool. is this set up for a b16/itr or gsr manifold?
Old Jun 8, 2005 | 05:11 PM
LeftCorner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">cool. is this set up for a b16/itr or gsr manifold?</TD></TR></TABLE>All B-series TB's have the same bolt pattern so it will fit any of the B-series manifolds.
Old Jun 8, 2005 | 07:27 PM
25 Year Member
right, but the gsr's use a weird spring return... i'm upgrading to a skunk2 mani on my gsr, so i need a b16/itr style to go with th emani and my itr throttle cable..
Old Jun 9, 2005 | 06:51 PM
LeftCorner's Avatar
Not from a 94+ GSR w/ the throttle cable coming from the other side. Has the spring return on the "normal" side.
Old Jun 9, 2005 | 06:57 PM
nfn15037's Avatar
Or you could use the throttle rotor and spring from any Civic or Integra besides the GSR.....weird 11mm nut
Old Jun 18, 2005 | 10:05 AM
LeftCorner's Avatar
Bump
boostedEBP
Apr 24, 2008 04:07 AM
R-Toyz.com
Oct 23, 2004 05:24 AM
