!@#Spark Plug Gaskets
Old Feb 9, 2002 | 10:51 AM
arren123's Avatar
Default !@#Spark Plug Gaskets
How did you guys take off the spark plug gaskets on your Z6 or Y8 valve cover?
The gaskets seem to be baked on and stuck. I pulled on it but it just tore apart.. The ring is still stuck in between the crevices. I'm spraying gasket remover and scraping, but its going really slow. I can't find anything that will fit in the crevice. There has to be something that is small enough yet strong enough to fit in the crevice.
What do you guys use?
Old Feb 9, 2002 | 11:39 AM
arren123's Avatar
Default Re: !@#Spark Plug Gaskets (arren123)
Never mind. It was a bitch. But I found out that there was a metal ring that held the spark plug gasket down.. it took a long time to remove though..
Jaydeep
Honda Civic (2001 - 2005)
Aug 20, 2012 08:13 AM
DEPintheCurve
May 31, 2009 05:37 PM
LeaveMeAloneClifford
Jan 7, 2008 12:01 PM
platinum00
Sep 23, 2003 07:08 AM
