Would a "slight" blown headgasket = low compression?
Old Feb 9, 2002 | 10:37 AM
Ri5e's Avatar
Default Would a "slight" blown headgasket = low compression?
I'm so confused now why my compression is low in 2 cylinders but oil level never changes.
But my radiator fluid, there is some leak somewhere because it dissapears every 2-3 weeks.
Could a "slight" blown headgasket cause for me to loose some compression.
But then again, I see no white smoke or any smoke coming out from the exhaust...
HELP!
Old Feb 9, 2002 | 12:48 PM
earl's Avatar
Default Re: Would a "slight" blown headgasket = low compression? (BG Boost)
How low is your compression? I doubt that the two are related. If you were losing a lot of compression into the head, you would be overheating also. Probably a couple of slightly burnt valves causing the low compression and a slight head gasket leak causing coolant loss. Maybe time for a head rebuild?
Old Feb 9, 2002 | 02:15 PM
rjardy's Avatar
Default Re: Would a "slight" blown headgasket = low compression? (earl)
you bet
Old Feb 10, 2002 | 09:54 AM
2000_Civic_Si's Avatar
Default Re: Would a "slight" blown headgasket = low compression? (rjardy)
YES, it would cause it to have low compression numbers.
T3T495GSR
Jul 18, 2005 11:04 AM
97itr86
Oct 30, 2004 08:51 AM
nd8ch
Feb 26, 2003 08:10 PM
shadowdawn
Oct 11, 2002 02:07 PM
GSR44
Jan 11, 2002 09:58 AM
