Hoosier r3s03's
Ok. I've asked in a few posts in this forum and have recived no answers, and can't find anything in the search function with any useful info. I would like to know if 225/45-15 r3s03's will fit on a '92-95 civic(hatch), and what width/offset(15" wheels) you are running or is required to get them to fit. My hatch is quite low after cross-corner-weighting and i'm currently running 205/50 r3s03's and they rub on certain occasions(curbs)- I believe on the front fascia(on the corner where it meets the fenders). I also have adjustable camber-2.4 degrees in front. Anyone use these on 5th generation civic??? Experience with similar set-up greatly appreciated.
Thanks.
Thanks.
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
on my 94 si, i run the 225/45 on 15x7 te37 +43mm in front for autocross. for roadrace, i run 225/45 all around on +45mm 15x7 kosei's. my car is quite low after my corner weighting also. good enough answer?
thanks guys.
I've got wilwood dynalites on the front w/ 11.5" rotors, and they barely clear my K1's with a 38mm offset. The 45mm offset K1's won't fit w/o a 5mm spacer. What to do, what to do...hmmm... I guess i'll have to stick w/ the 205s. Bummer. Maybe some different wheels(45mm offset) are in my future.
Spicylikcajun
May 14, 2007 10:53 AM
MassScene
Nov 22, 2006 11:13 AM
DSPDA3
14
Apr 17, 2006 10:13 AM
rambler
10
Sep 11, 2002 06:38 PM
