HELP!! All gauges dead! Car won't start! 95hatch w/gsr
Old Jun 6, 2005 | 05:28 PM
hybridmyk's Avatar
Default HELP!! All gauges dead! Car won't start! 95hatch w/gsr
Here's the situation. I have a 95 Civic hatchback with a 95 Integra Gsr swap. Everything was working fine. No codes. Vtec pulled hard. Perfect. Then, one day all my needles just died on my gauges. The lights on the cluster behind the gauge faces weren't iluminating. Turn signals don't work, just hazards. I can't even make my check engine light turn on. Tac, speedo, gas, temp...all dead. And my tail lights don't light up. Then, a couple days later, the cluster lights up and the tail lights, still nothing else, but now my air fuel gauge, shift lights n turbo gauge don't work too. WTF? (turbo gauge used to be hooked up when i was supercharged, but power still goes to it.) So, all of that won't light up n e more. Furthermore, now my car won't start. I'm sure it is just my starter that finally crapped out tho. It's been giving out.
But, the main prob, my cluster n gauges.
I've checked all my fuses. I've checked my engine grounds. I dunno what's up. I have the Honda Civic book that Honda uses, the big green one, n it has all the wiring diagrams + i have other print outs of more detailed wire diagrams, so I am about to get started on all that. What else? Bad relay or relays? N e thing would help. Thanks.
Old Jun 6, 2005 | 05:50 PM
ko's Avatar
ko
did your car die while driving?
Old Jun 6, 2005 | 06:03 PM
hybridmyk's Avatar
nope. all the needles on my cluster did tho.
Old Jun 7, 2005 | 03:03 AM
ko's Avatar
ko
Default Re: (hybridmyk)
check you battery, make sure there is no corrosion build up. From there I'd check the alt.
Old Jun 7, 2005 | 03:53 AM
Hurricane's Avatar
Default Re: (ko)
Honda Gremlins
Old Jun 7, 2005 | 04:05 AM
DJ_SaNdOz's Avatar
Default Re: (Hurricane)
check the ignition switch.
Old Jun 8, 2005 | 01:32 AM
hybridmyk's Avatar
i'm not that concerned with the car not starting right now so much as my instrument cluster being dead n my other gauges too. the starting prob is my starter. it's been crapping out for a few months n prob just took a dump n died finally.
Old Jun 8, 2005 | 03:26 AM
ko's Avatar
ko
i bet its the alt.
Old Jun 8, 2005 | 03:57 AM
DJ_SaNdOz's Avatar
Default Re: (ko)
I had a short in my ignition switch that did the same thing.
Old Jun 8, 2005 | 09:27 PM
hybridmyk's Avatar
Default Re: (ko)
Old Jun 8, 2005 | 09:40 PM
ZedEx's Avatar
Did you check your fuse box? A similar occurance happened with our H22 '94 Hatchback, and the Oxygen Sensor was grounding out, causing the Fuel Pump fuse to 'pop'
So we took the radio fuse (they're both 15) and replaced it into the Fuel Pump fuse location, and it got us home at least.
Check your Fuse Box... And if that is the problem... Then comes the fun part: Checking where you're grounding out
Good luck.
Old Jun 9, 2005 | 01:21 PM
hybridmyk's Avatar
i checked all my fuses. they're all good under the hood and under the dash. I don't think it is my ignition switch because my fuel pump wouldn't turn on if I had a bad one. My fuel pump works and the car runs fine when I push start it. So my starting problem is probably just the starter.
DOES N E 1 KNO WHY ALL MY INSTRUMENT GAUGES ARE DEAD? GAS, TEMP, TAC, SPEEDO =DEAD.
Will a bad main relay effect the cluster?
Old Jun 9, 2005 | 01:26 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
its a relay or fuse near the passenger side shock tower
Old Jun 9, 2005 | 01:51 PM
DJ_SaNdOz's Avatar
Your fuel pump may not necessarily be affected by a bad ignition switch. Mine was shorting out & would kill the guages & guage lights, and would randomnly cause the car to die/not start until one day it finally went kaput on my way to work.
Old Jun 9, 2005 | 03:29 PM
hybridmyk's Avatar
ok. keep the ideas coming guys. i will check my connection to the fuel pump. I will check the relays n the ignition switch. I'll let ya kno.
Old Jun 9, 2005 | 05:40 PM
Neotrix's Avatar
i had that issue sorta i had a 94 hatch with 95 GSR and one day my cluster went out but i car still started my my vtec wound not cut one i think i had i blown fuse....Double and triple check evert single fuse....Just my thoughts
Old Jun 9, 2005 | 05:45 PM
aown61's Avatar
i had the same problem, it was a fuse.
took all my instruments, lights out sounds like you have other problems aswell though
Old Jun 9, 2005 | 10:38 PM
hybridmyk's Avatar
Old Jun 10, 2005 | 09:56 AM
CHiNkStEr's Avatar
maybe your alternator went bad and killed off your battery?
Old Jun 10, 2005 | 06:21 PM
Neotrix's Avatar
make sure your vtak have triple A batteries and make sure you radio is top off
with 5w-30 vtak oil lol.... But seriously have u found the problem yet? And is that your car in the pick in Oceanside?
Old Jun 10, 2005 | 10:17 PM
jdecks23's Avatar
Default Re: (Neotrix)
happen to me, turned out to be a short in the main alternator wire from when i swapped a new harness with the motor.
Old Jun 10, 2005 | 10:32 PM
GoT HaTcH's Avatar
Default Re: (jdecks23)
i had this problem too after my swap, i just added some extra ground wires and it solved my problem.
Old Jun 10, 2005 | 11:41 PM
JDM*BUBBLE's Avatar
Default Re: (GoT HaTcH)
I had the same problem
change ur fuse box under the dash
Old Jun 11, 2005 | 01:24 AM
Elementalfiend's Avatar
Default Re: (ZedEx)
Forgive me for being retarded, I'm new to Hondas. But is that a newer front end mounted on the EG body? Or did they make one of that style from the factory?
Sorry can't help you with your problem.
Old Jun 11, 2005 | 01:43 AM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: HELP!! All gauges dead! Car won't start! 95hatch w/gsr (hybridmyk)
Check all your grounds. Transmission as well as the block.
