Suspension & Brakes Theory, alignment, spring rates....
Suspension installation
Old Jun 6, 2005 | 05:28 PM
Corruption's Avatar
Default Suspension installation
What's going on guys? So I went to this shop today and this guy told me he'd install my stuff next week . I'm pretty sure I'm going to have him drop it 1.75" in the front and 1.50" in the back, do you guys feel that this is a good choice? I was originally going to go a bit lower however the roads around here can be rough and can be taxing on the suspension. Another thing I was wondering is if all the adjustable sleeves that came with the Ground Control's universal with all the springs? Lastly, are there any special instructions that I should give this mechanic that will make his life easier and save me money in the long run, is there anything specific to my application (01' Accord LX) that needs to tended to? Thanks guys
Old Jun 7, 2005 | 05:42 AM
Corruption's Avatar
Default Re: Suspension installation (Corruption)
bump
Old Jun 7, 2005 | 08:58 AM
Corruption's Avatar
oh well, ill figure it out on my own, thanks anyways
Old Jun 7, 2005 | 10:44 AM
00R101's Avatar
Maybe nobody's answering because they are unsure what you are trying to accomplish and what equipment you are installing. I guess you are going to use GC but not understanding your questions about them.
Old Jun 7, 2005 | 07:26 PM
Corruption's Avatar
just wanted to make sure that the sleeves for the GC's which are being installed with the KONI's are universial, additionally i wanted to know if there's any special instructions i can give my mechanic to make his life easier. lastly, id like to know if there's any rule of thumb in terms of the height of the car when the thread is adjusted? like if i were to move the ring around my sleeve 360 degrees how much would it increase/decrease my height? thanks
Old Jun 7, 2005 | 10:46 PM
dannylDAsport's Avatar
Default Re: (Corruption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corruption &raquo;</TD></TR><TR><TD CLASS="quote">just wanted to make sure that the sleeves for the GC's which are being installed with the KONI's are universial, additionally i wanted to know if there's any special instructions i can give my mechanic to make his life easier. lastly, id like to know if there's any rule of thumb in terms of the height of the car when the thread is adjusted? like if i were to move the ring around my sleeve 360 degrees how much would it increase/decrease my height? thanks</TD></TR></TABLE>
different brand sleeves... different quility of material. make sure that ur GC's coilovers are made for koni shocks.
trial and error my friend cant say how much of a drop. just advise the mechanic how low u want it. i set my by wheel gap.
Old Jun 8, 2005 | 05:41 AM
Corruption's Avatar
I got the GC's specifically with the KONI's, my question was are all the GC compatible sleeves all unversial with the set of 4 or what? Is there a rule of thumb, other than measuring the distance between the wheel and the wheel well, to find out the distance change when you turn the metal clip up/down? thanks
Modified by Corruption at 11:59 AM 6/8/2005
Old Jun 8, 2005 | 08:00 AM
Corruption's Avatar
If someone could give me an answer before monday, it would be great since it will save me money :0
Old Jun 8, 2005 | 08:31 AM
Tyson's Avatar
Ground Control
530-677-8600
Old Jun 8, 2005 | 02:00 PM
Corruption's Avatar
my only real question was are the adjustable sleeves universal...that's all, it's not worth me calling gc for it
KraZyCHOWMEIN
Mar 25, 2016 05:14 AM
patrickstar
Honda Civic (2006 - 2015)
Jun 19, 2009 12:09 PM
ridikk
Suspension & Brakes
Mar 28, 2009 07:21 PM
JDMoneDC5
Sep 16, 2008 06:03 PM
