stock ls rods with arp rod bolts
Old Jun 6, 2005 | 05:24 PM
black_si's Avatar
Default stock ls rods with arp rod bolts
whats the torque specs on the stock ls rods with arp rod bolts and will the standard size ctr piston fit in my ls block
Old Jun 6, 2005 | 05:26 PM
5STAR3's Avatar
Default Re: stock ls rods with arp rod bolts (black_si)
26lbs i believe.
Old Jun 6, 2005 | 05:29 PM
Yambor's Avatar
Yes it will. But you will have to mill 1mm off each side of the small end of the rod...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_si &raquo;</TD></TR><TR><TD CLASS="quote">....will the standard size ctr piston fit in my ls block</TD></TR></TABLE>
Old Jun 6, 2005 | 10:19 PM
hybrid_vtec's Avatar
Default Re: stock ls rods with arp rod bolts (envision2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg &raquo;</TD></TR><TR><TD CLASS="quote">26lbs i believe.</TD></TR></TABLE>
I believe it is a 2-step torque process ending in torqueing the rod bolts at 26 or 28lbs. I will double check..........
j0nb0y22
16
Oct 16, 2007 10:04 AM
turbod da
Aug 21, 2007 08:41 PM
Vance
Feb 21, 2007 05:32 PM
SleepinTeg
May 31, 2005 07:03 AM
SiBuddy00
Feb 28, 2005 01:06 PM
