How to disengage clutch safey in integra?
Old Jun 6, 2005 | 04:34 PM
brickonwheels's Avatar
Default How to disengage clutch safey in integra?
Over the past two days, i have been wiring in my remote start system into my 96 integra and have everything hooked up. I can remote start my car if i push in the clutch but can not without. So i need to know how i might be able to disengage the clutch safety switch at the top of the clutch pedal, if any of you can help, that would be great.
And i know all of you would worry about the legality issues of the remote start, but i am well aware and have decided to go ahead with it regardless. But thank you for your concerns
Old Jun 6, 2005 | 04:36 PM
jennifermike's Avatar
Default Re: How to disengage clutch safey in integra? (brickonwheels)
just cut the clutch wire, i think, hell i cant remember
Old Jun 6, 2005 | 04:43 PM
think my friend, think
Old Jun 6, 2005 | 04:49 PM
Default Re: (brickonwheels)
i did it in my wifes car, like 4 years ago, man i cant remember. i think there is 1 or 2 wires going to the clutch. cut one, put it in nutral and start it with out the pedal, if it doesnt work reconnect it and cut the other. that all i can think of
Old Jun 6, 2005 | 04:52 PM
Default Re: (jennifermike)
just found this
"If you dont care about the clutch as a safety switch, you could run a ground wire to the wire on the pedal. But in doing this you will be able to start the car without the need to have the clutch pedal pushed down. " i dont think i did that though
Old Jun 6, 2005 | 04:55 PM
just connect both wires together, i think that how i did it
Old Jun 6, 2005 | 04:58 PM
I found the two wires, there is a pink one with blue stripes and a black one
Old Jun 6, 2005 | 05:02 PM
i think you just connect them together. search it in the archives i typed cluth bypass. its the same civic/integras
Old Jun 6, 2005 | 05:13 PM
well, i searched and it came up empty. Can anyone confirm this?
Old Jun 6, 2005 | 06:26 PM
chris23492's Avatar
just did this a few weeks ago,really easy to do. Cut the two wires going to the clutch and connect them together . Your problem will be solved. Be carefull car will be able to be started while in gear ex.
Old Jun 6, 2005 | 08:00 PM
Dropped90Integra's Avatar
Default Re: (chris23492)
I agree... I'm pretty sure you can connect both together and it'll start without having the clutch pressed in. I plan on wiring my safety switch to my cruise control buttons with carefully hidden wires are a security feature
Old Jun 6, 2005 | 08:28 PM
That's awesome, best of luck to you with that.
Old Jun 6, 2005 | 08:32 PM
Thanks, to start the car both buttons are gonna have to be held in and than turn the key.... should be pretty phat, lol... can't have enough security these days
Old Jun 7, 2005 | 07:40 AM
7k rdlne's Avatar
Default Re: (Dropped90Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropped90Integra &raquo;</TD></TR><TR><TD CLASS="quote"> I plan on wiring my safety switch to my cruise control buttons with carefully hidden wires are a security feature </TD></TR></TABLE>
keep us posted on how this turns out, im interested to know
Old Jun 7, 2005 | 08:44 AM
Liquidgsr's Avatar
Default Re: (7k rdlne)
for my clifford i was told to wire the blue one and tap it into the clutch safety switch, so i have to push the clutch in when i want to manually start it, but when i autostart it still works.
EGed up from the seat up
Apr 6, 2011 06:33 PM
Nataku
Oct 19, 2007 11:39 AM
kroze
Honda Civic (2006 - 2015)
31
Oct 2, 2006 07:43 AM
brickonwheels
Audio / Security / Video
Jun 9, 2005 01:33 PM
onetwothree
36
Jun 6, 2003 08:07 AM
