Anyone ever put a calbe tranny in a eg?
I have a 94 civic iam doing a ls swap in it. The motor is from a 90 ls
and i have converted my car from hydro to cable and now iam wondering what mounts to use for this swap yes i have searched couldnt find anything clear enough to keep me form posting...
so it would really help me out if someone could tell me what mounts to use...
94 civic------90 ls motor-----cable tranny
My car is at a shop were we are woring on it so if i have to weld its not a prob please let me know..
You didn't search properly because this is a very common swap and there are lots of posts about it
to help you out...in the Search section
under search for type in b18a swap
under Forum select 92-00 CIVIC section
You need 94+ integra mounts to use on this swap
Thank you,
seems like you needed help to on a swap hummm..
anyway anyone nknow how i cant fabbricat the 93 integra mounts to work on this swap???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seeeya04 »</TD></TR><TR><TD CLASS="quote">Thank you,
anyway anyone nknow how i cant fabbricat the 93 integra mounts to work on this swap???</TD></TR></TABLE>
Yea I am in the process but not installing the swap anymore...not till next year.
Building up LS/Vtec instead of a direct LS swap into my coupe.
Your best bet would be to buy the hasport cable-to hydrolic kit and put that on.
My friend is in the same boat and wants to install the clutch pedal in his 93 4-dr....the pedal itself is appart from gas and brakes.
Not sure about installing the clutch pedal directly tho...not much info on it
No we fabricated a nice little pedal setup thats not my concern my concern is wondering if i can fabricate the 93 integra mounts to work..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seeeya04 »</TD></TR><TR><TD CLASS="quote">No we fabricated a nice little pedal setup thats not my concern my concern is wondering if i can fabricate the 93 integra mounts to work..</TD></TR></TABLE>
The stock tranny, rear mounts wont work
The uppder driver side should work
but to save yourself problems I would recomend getting mounts from a 94+ teg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seeeya04 »</TD></TR><TR><TD CLASS="quote">so with the 94 teg mounts it should be direct bolt in?</TD></TR></TABLE>
yes.
Check this out
https://honda-tech.com/zerothread?id=932915
yes.
Check this out
mario_pic
Nov 26, 2007 02:18 PM
xbeaverx
Sep 22, 2004 10:04 PM
WingNutRacer98
Jan 16, 2003 05:05 AM
