Radiator Fan Assmbly Need quick answer.
The pas side fan is the colling fan and the drivers side fan is the AC fan right. So if i have no AC i can take out the AC fan? Also my cooling fan is blowing the opposite way. When the fan is on the air blows out of the engine. This sucks for driving since the fan and ram air are acting against each other, but since its hooked up the the on switch on the ignition when i am stopped i can leave the car in the on postion and the hot air is pulled out by the fan. So i guess it sucks a little but it ain't that bad.
PS the question is can i take out the AC fan if i have no AC and im making sure the drivers side is the AC fan.
sEan
sEan
Yes the driver side fan is an A/C fan. But as far as your situation with your radiator fan, why is it blowing the opposite direction in the first place, an easy solution is to switch the wires. I might not be understanding your situation as thoroughly, but that might help
kholmes
May 11, 2005 08:39 PM
