***BOV HKS Filter pipe ****
i'm getting rid of some parts that i have around. i'll have pics up soon
-95 d16z6 head complete minus intake manifold and dist. 50.00
-HKS super sequential Style BOV with purple insert and stock inser thas some scrapes works and sounds just like the real one.guy on Honda-tech had HKS bought one of these took both apart and he siad they were same and he used both. coem with NEW flnage, O ring, C clip, everythign needed. 120 shipped Cclip and O ring not pictured but included
-JDM hks bov flange/pipe 2in pipe 25.00
-JDM hks filter green foam mushroom 25.00
-JDM nissan sr20det sensor 5.00
-garrett t25 NOT DSM needs rebuild has wastegate set at 6psi, hads oil drain tube and both coolant lines. 40.00
-dodge daytona t3 .42 .48 needs rebuild has busted bolts on downpipe and has downpipe flange good for paper weight.... 5.00
-2.25 manderl 180 degree U bend with 12" legs 12.00
-MSD rpm actavation swtich with 4800 pill relay..l everything needed to install 30.00
-JDM d15b stock exhaust manifold with heat sheild 15.00
-95 d16z6 stock exhaust manifold with heat sheild 15.00
-2 88-89 pm6 15.00 each
-2 misc. D series throttle bodys 5.00 each
-d15b7 NEW timing belt. 30.00[/img]
Bspec18
Jul 28, 2004 09:44 AM
