B18A(ls) motor into a crx????
Old Jun 6, 2005 | 11:06 AM
dylokjai's Avatar
Default B18A(ls) motor into a crx????
just pick up a 88 crx hf for 200 bucks with a blown head gasket. Im planning on swapping a 91 integra LS motor into my crx. what will i need to do a complete swap? motor, harness, what else?
Old Jun 6, 2005 | 11:09 AM
DohcVtecCrx's Avatar
Default Re: B18A(ls) motor into a crx???? (dylokjai)
You will need the full swap:
motor
ecu
axles
tranny
rear mount bracket
intershaft
da or aftermarket shift linkage (the da one you have to cut 2 inches out)
The other parts you have to buy:
motor mount kit (place racing, hasport, cheaper ebay ish ect)
Custom elbow grease:
Bang the crap out of the engine bay were the alternator will sit (just enough to dent it in enough so it will not rub.
Pop the outter ring on the back of your front knuckles so the axles will not bind.
That about sums it up over a stock motor swap. All the swap parts will be included if you buy a swap from a reputable jdm engine seller. hmotorsonline.com is the ONLY place I get swaps from.
OH yeah use your stock hf harness.
Spoolinator
Nov 13, 2005 01:59 PM
b20turbojason
Apr 7, 2005 09:48 AM
Serdar
Jan 13, 2005 05:12 AM
ironchef25
10
Oct 29, 2003 09:14 AM
sickmofo
Nov 21, 2002 11:36 PM
