Question on parts compatibility
Old Jun 6, 2005 | 07:06 AM
Mag00n's Avatar
Default Question on parts compatibility
I have a jdm b16a with S1 trans. The clutch may need a new pressure plate and/or throwout bearing. Are these parts identical/interchangeable to Bseries integras with cable trannys?
Old Jun 6, 2005 | 07:24 AM
type Gendy's Avatar
Default Re: Question on parts compatibility (Mag00n)
u base the clutch on the tranny you are using, spline count i do belive
So i'm guessing an integra may be different and u may look to other b16's for a clutch... EX: 99 civic si
(This is just what i've gathered from reading, cant verify however)
Old Jun 6, 2005 | 07:25 AM
Mag00n's Avatar
Default Re: Question on parts compatibility (type Gendy)
But the other b16s from the states are all hydro trannys. Are the clutches the same?
Old Jun 6, 2005 | 07:36 AM
type Gendy's Avatar
i dont think hydro vs cable is an issue, thats just how the clutch is engaged. Its the transmission being used that matters, and what the spline count is.
Old Jun 6, 2005 | 08:36 AM
EP3_05's Avatar
Ok the JDM b16a S1,J1,Y1 should all use the 90-91 integra clutch assembly and bearings.
The YS1, or any 92+ cable or hydro transmission uses a larger splined disc but the pressure plates are the same for the 90+ b series transmissions.
From what you have said I would go with the 90+ pp and 90-91 throwout bearing.
Old Jun 9, 2005 | 08:27 AM
Mag00n's Avatar
Default Re: Question on parts compatibility (91civic)
thanks
orange91civic
Mar 30, 2008 06:17 PM
Beau Gotti
Feb 27, 2006 09:40 PM
Mag00n
Jun 9, 2005 08:27 AM
420aNT
Dec 30, 2002 06:31 PM
racerxadam
Jan 30, 2002 12:05 PM
