B16 WIRING HARNESS
I can not seem to figure out where everything plugs up guys and gals. PLEASE HELP! Search is down, I TRIED, and I am trying to get this figured out ASAP.
I am doing, well trying to do my swap this time instead of paying some one to do it. I took my blown motor out about 4 months ago and am just now getting around to putting my new one in. I can not figure out where everything (wiring harness) goes. Do all the plugs have to be pluged in? Which ones do not if no? Also there are 2 O-ring terminals on the harness, and I know one goes to the alternator but where does the other one go? Is it the fuse box? Another reason I am having problems is I relocated the fuse box into the car so I am all screwed up. I should have paid someone to do and watched. Any info or PICTURES would be GREAT!
The car is of course a 90 CRX with a B16A SiR and is OBDO. I still have the resistor box. I think that is about everything that you will need to know to help. Thanks once again everyone.
it had a B16 in it, I blew it up. I just had it built and am starting to put it back in. I just can not seem to figure out the easy stuff. The Vtec wiring has been done. I just need to drop the motor and plug up th wirign harness but I seem to have some plugs that are not pluged up. Am I missing something?
and for trading the seats for the info, its a DEAL. Now what is our address so I can send them to ya!
yeah the other o ring one goes to the fuse box. WHat other plugs are not on? I think you will have one that doesn't plug in anywere cause the hf have egr.
[IMG][/IMG] http://www.we-todd-did-racing....D.jpg
Here is the link to a picture of the two things that I can not figure out where they go. They go are the clear plug with 3 wires and the o-ring right across from it.
PLEASE HELP!
PLEASE HELP!
O ring one goes to either your enginebay fuse box or your starter ground. the other...well I cant tell what part of the harness its on by the pic but from what I can tell its near your dist. and vtec unit. beats me man, I dont have one like that one mine.
STARTER GROUND, were do I ground it to? Doesn't the power cable from the battery go to the post on the starter?
that link will show where the clear plug is close to? Is that the one that I do not hook up then?
You will have a postive wire coming off the battery to the starter (not shown in your pict). The pict u have there starting on the right...the white wire goes into the fuse box the next one down goes to the top of the starter next one down is your thermostat ground. The whole thing is plug and play dude very easy to do that is why noone is responding. Like nike says...just do it
yeah i know it should have been simple but the one plug that doesn't get plugged in because it's a Hf confused me, and I didn't know where to ground the last o-ring. Thanks for the help. First time doing this and you guys were my only help.
AWD: Jeff
Aug 13, 2007 10:14 AM
HuggerHatch
Apr 30, 2005 06:02 PM
sporkcrx
Apr 29, 2003 03:08 PM
