More power on a 94 RS?
Hey,
I'm new to H-T, and I recently bought a '94 RS. The car is completely stock, so I'm wondering what I can do to add some power without having to do a swap? I have around $6-700 to spend. Thanks HT!
How about you take car of your suspension first..Having all the power in the world doesnt mean anything if you cant put it to the ground. Nice start by the way you have a really light integra
Turns out that I have the same car you do.
I agree, get a good set of coils and shocks that would work together with a mild drop (.5"-.75") and then get a Type R rear sway bar. That thing will handle like its on rails. Then learn to drive your car to its limits without pushing it over.
more power on RS? and you just bought the car? first off... go get a tune up and make sure everything is running correctly and no leaks or holes anywhere second you'll be spending more and more money as you go on... you'll want more and more power!! heres all the **** i threw in my car and spent well over $2000 and i just got the car like a few months ago...
1994 integra GSR
98 GSR FRONT BUMPER WITH CLEAR SIGNALS LIGHTS
INTEGRA TYPE R SPOILER
GSR RIMS WITH KUMHO ESTA TIRES
OPTIMA YELLOW TOP BATTERY
EPOWER VOLTAGE STABILIZER - WELL WORTH IT GET IT !!!!!
4 GAUGE GROUND WIRE
CUSTOM PAINTED RED VALVE COVER
TYPE R SWAY BAR UNDERNEATH
ADJUSTABLE SHOCKS - TOKICO ILLUMINAS
GROUND CONTROL ADJUSTABLE COILOVERS – DROPPIN THE CAR TO 0 – 3”
ACT STAGE 1 RACING CLUTCH
SKUNK2 SHORT SHIFTER WITH GREDDY SHIFT ****
GREDDY EVO EXHAUST
COLD AIR INTAKE W/ AEM BYPASS VALVE
LOW TEMPERTURE THERMOSTAT
and more ****... just got a brand new sound system that i havent installed yet!
GOOD LUCK HOOKING UP YOUR TEG!!!
1994 integra GSR
4 GAUGE GROUND WIRE
GREDDY EVO EXHAUST
yes i agree save up and boost the b18b...i wouldnt even buy an exhaust system...thats what i did ....i didnt waste my money on all that stuff like 2.25 exhaust and header..cause i knew id go turbo and would get a 3.00 exhaust and would have no need for an aftermarket header
