need help with sensor on intake manfiold (ASAP)
ok.. heres the prob..
im going from a 99 B16A2 to a 98 JDM B18C
i have this sensor on my B16 intake manifold.. (red circle)
but i dont have it on my B18 manifold..
its easy to just say hey.. swap out the fuel rail.. but where would i mount this hose>? (blue rectangle)
why not just swap the whole intake manifold and fuel rail assembly??
because i dont see where any of those would go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">why not just swap the whole intake manifold and fuel rail assembly??
because i dont see where any of those would go</TD></TR></TABLE>
the two manifolds aren't interchangeable.the two heads have different stud patterns for the manifold.
are you keeping this OBDII,or using an OBDI ECU?
Chris
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pb16b »</TD></TR><TR><TD CLASS="quote">jdm b18c sir-g right? hmmm... yeah the manifold won't fit. swap the fuel rail and t it off the intake manifold before the pcv.</TD></TR></TABLE>
if i swap the fuel rails.. i wont have anywhere to put the hose.. (blue rectangle in the picture)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 »</TD></TR><TR><TD CLASS="quote">if you're going from b16 manifold to type-r then they are interchangable.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterdriver »</TD></TR><TR><TD CLASS="quote">that looks like an itr manifold on the b18c, if it is then its interchangable</TD></TR></TABLE>
if it is,then it's still adapted to the C1 stud pattern(a Skunk2 mani for instance),and still won't fit in a B16 head.
...or does the original poster have an ITR engine?
Chris
Chris
LS1Bait
Jan 15, 2009 07:04 AM
racingant
Oct 9, 2005 08:15 PM
