Problem with start up, '94 Civic Si
Old Jun 5, 2005 | 04:11 PM
EH3Kid85's Avatar
Default Problem with start up, '94 Civic Si
This has happened to me twice in the course of like, 4 days, so i'm getting kinda worried.
Just got back from a run to 7-11. I get my cigarettes and gatorade and get back in my car. I start it up, it starts up, but then the revs dip really low and it stalls. I try to start it back up and it won't turn over. After a few more tries, it turns over, but it'll idle REALLY low, like in the 200/300 RPM range.
Same thing happened when I went to drop off my rent at my landlord's house just the other day.
Any ideas of what this could be?
Old Jun 5, 2005 | 04:35 PM
05em2's Avatar
Default Re: Problem with start up, '94 Civic Si (EH3Kid85)
same thing happened to me when i first got my used 93 civic ex, and i did all the/still trying to do all the major maintainances
oil change
spark plugs
bleed coolant
tranny fluid
replace dizzy
maybe throttle cable is not tight enough u can adjust it
try the fuel system cleaner that u pour in ur gas tank
it could be a lot of things...clutch pedal adjustment comes to mind too
also there's a forum about fixing bad idle, check it out
https://honda-tech.com/zerothread?id=699787..
Old Jun 5, 2005 | 04:36 PM
Crasian's Avatar
this may also be your problem....
https://honda-tech.com/zerothread?id=1267873
Old Jun 5, 2005 | 04:39 PM
EH3Kid85's Avatar
Default Re: (FarOutCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FarOutCoupe &raquo;</TD></TR><TR><TD CLASS="quote">this may also be your problem....
https://honda-tech.com/zerothread?id=1267873</TD></TR></TABLE>
Thanks man I'll check it out at work tomorrow (If it doesn't give me problems trying to get there )
Old Jun 5, 2005 | 07:30 PM
hybridmath's Avatar
Default Re: Problem with start up, '94 Civic Si (Jay-Dee-Em)
IF YOU WOULD BE WILLING TO PAY FOR SHIPPING I CAN GIVE YOU ONE FOR FREE I WORK AT JUNK YARD WHEN EVER THEY CRUSH A CIVIC I GRAB ALL THE RELAYS SENSORS ETC SEND ME AN EMAIL STEVE6025@AOL.COM OR POST REPLY IF INTERESTED I GOTTA HAVE 15 OR 20 MAIN RELAYS SITTING IN MY GARAGE
Old Jun 5, 2005 | 07:37 PM
TylerH's Avatar
Default Re: Problem with start up, '94 Civic Si (steve6025)
I'm going to guess a bad fuel pump, bad fuel filter, or a bad fuel pump rellay.
Old Jun 5, 2005 | 09:04 PM
tca0bell's Avatar
yeah the same thing happens to me but it only happens once in a while. recently i just changed the rotor and cap and its idling better now. i looked at the old rotor and cap and it had like..build up of white crap on the metal parts.
oscar206
Dec 17, 2017 10:44 AM
monkey_boi
Jul 9, 2009 10:54 PM
Trojan Man
Apr 28, 2009 05:53 PM
Civ94Driver
Dec 13, 2007 06:16 PM
jdm5lughatch
May 14, 2004 07:37 PM
